  • Replies 68
Given that the regulations for speedometers is +/- 10% accuracy, this is incredible.
Does this reg not also apply to speed cameras and guns themselves aswell? Im sure they also have a degree of inaccuracy.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5729899
I've actually heard from some one who works in the nsw gov, that all this is happening because the state is broke
Knock-on effect:- Keneally is actually doing O'Farrell a favour > to take a step towards balancing the budget.
In regard to your relevant comment Owen, O'Farrell is on record to have stated, "I want greater police presence (rather than fine people off the road)"
He wouldn't have to repeal an RTA intention as it hasn't been enacted yet.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5729921
funny how the governments in sydney are the ones that are broke and struggling and rather than finding positive ways to re emberse themselves - lets say take a pay cut for instance... on there almost obscene wages. they target the easiest and slyiest way to get "quick" bucks without any real retaliation and the sucess rate is going to be massive, not just for import drivers but all drivers.
what ever happened to the give aussies are fair go slogan?
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5729980
i think it would be fairly easy to torpedo this by disputing fines through court again and again.
Given that the ADR's give +/- 10% at 40kph you could argue that purely due to aus design standards that it is impossible to regulate your speed to the required standard.
The only way to ensure this (at 60kph) would be to drive a marked 6kph slower than the posted limit, with the possibility (due to above +/- error) of actually going 12 km under the limit (48 kph) and as such possibly obstructing traffic.
Win that argument a few times... job done.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5729993
It is a good point, but, how many people fined with doing 61 in a 60 zone are going to opt for the legal option? I would say, and I am sure this is an assumption of the RTA/Government also that the vast majority of these people will simply pay the fines.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5730011
i think if it were uncommon to be fined for that kind of offence you'd be right, but given the spike in cameras thats also planned, it would mean that being pinged for 61 would become quite common.
As the point hit is what would really hurt (i dair say the fine for 1 over would be low) i think disputes could go up.
Plus if someone gets one case dismissed based on my above suggestion, i think news would spread and it would start to snow ball.
that said... i can also see them updating the ADR's to make +/- 0% the requirement and then defecting you when you dispute it.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5730033
Personally i think its the opposite
If you look at what the execs in big business get paid, and then look at government, i think the problem is that its such a low paying job for the amount of responsibility and stress, that no half intelligent person would actually even attempt it. End result is we get people in power like those we have now, from federal to state to local. No one with any actual background in running a major enterprise (which is what govt is).
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5730061
unless they change the ADRs surrounding speedo readings and calibrations there is no way if you took a 61kph fine to court would it hold up
Why? Have you read the ADRs?
Everyone has been statng that it's +/-10%... But that's incorrect. The ADRs actually state a speedo has to be +10% accurate, NOT +/-
That meaning, your speedo can show your actual speed, OR upto 10% over your actual speed.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5730189
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
