  • Replies 68
Pathetic... I cant believe the people of NSW are just gonna cop this... Are we so "Civilized" that we just ask for more and more dick in the ass from the government and the RTA?
I dont understand how the people of australia can allow there government get away with so much? Like really getting a fine for going 61? Who the f**k notices there at 61? Let alone see it? You could be seeing the needle on 60 but your going 61...
And this whole this with 2000+ mobile camera's HOW the f**k do we just put up with this? THERE is no f**king proof they work for f**k sake because if no one notices the signs they dont slow down for that brief period of road.. Because honestly come now guys i see people see "Oops camera slow down"" Then once there pass ZOOOOOM they go in there super fast family carriers.. Its funny how the government can feed us so much bullshit media and entertainment that we dont even bother rise up when there clearly f**king us in the ass over and over...
End rant..
Sid
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5731635
Just to clarify, I said there were going to be 2000+ mobile speed camera sites, not 2000+ mobile speed cameras. The justification for their introduction was to monitor traffic "red spots" only, which numbered around 140. Now that they have been introduced under that pretense the RTA wants to increase the sites by a couple of thousand, no biggie......:unsure:
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5731774
oh, so you mean the average driver DOESN'T calibrate their speedo on a weekly basis after they pump up their tyres while abiding by the designated speed limit at all times? :O
Unless your speedo starts eating the gear drive, you don't need to calibrate them, this is why they have to be between 0 and 10% over read at any time for any configuration of tyre approved by the manufacturer.
Most cars over read by at least 3% on brand new tyres. Oh and new to worn out tyres will alter reading by approx 0.5%...
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5732091
What's the bet this one gets settled, with a confidentiality clause, way before September.
http://www.heraldsun...x-1226018034109
Constable Pitman's court transcripts should still be obtainable through FOIA.
She certainly seems to have a case.
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5732470
This, is, horse s***.
How the hell do they intend to keep this in? 1kph? How long does it take the average car to accelerate 1kph over the limit without the driver intending or noticing? 1,2 seconds? More, less? Even factory and after-market cruise controllers sometimes struggle to regulate your speed within 3kph. Do they honestly believe a driver should be checking their speedo LITERALLY every second?
How the F*** is that logical or safe? A slight decline in the road over 2 or 3 seconds could do this. For those whose speedos read within 1 or 2kph lower, and DON'T intentionally speed, you're all about to get f***** hard...
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5732479
SMH states that the ADRs specify a 10% margin for error either way, yet the actual ADRs say that the margin for error only applies that the car is always going equal to or less than the speed displayed on the speedo...
I wonder what else in that article is incorrect?
TL;DR - Sensationalist journalism
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5733410
Two words: GHOST PLATES.
Cameras won't be an issue anymore with a pair of those things on your car.
lulz
http://www.skylinesaustralia.com/forums/topic/61870-ghost-plates-ghostplatescomau/page__view__findpost__p__1167458
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5733487
^ ^ ^ Read Craig's post #22 HOT_R33
Familiar? :rofl:
".....he drives a holden"
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5733504
The new ADR rules of +10% only applies to new cars complied as new cars.
It doesn't apply to any older cars, it doesn't apply to used imports, a car may be tested to have a speedo 3% higher than actual speed when new, give it 10 years and the speedo can go either way, no matter if the car is a Hyundai or an R35. Digital speedos arn't any better either.
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5733652
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
