  • Replies 68
Pathetic... I cant believe the people of NSW are just gonna cop this... Are we so "Civilized" that we just ask for more and more dick in the ass from the government and the RTA?
I dont understand how the people of australia can allow there government get away with so much? Like really getting a fine for going 61? Who the f**k notices there at 61? Let alone see it? You could be seeing the needle on 60 but your going 61...
And this whole this with 2000+ mobile camera's HOW the f**k do we just put up with this? THERE is no f**king proof they work for f**k sake because if no one notices the signs they dont slow down for that brief period of road.. Because honestly come now guys i see people see "Oops camera slow down"" Then once there pass ZOOOOOM they go in there super fast family carriers.. Its funny how the government can feed us so much bullshit media and entertainment that we dont even bother rise up when there clearly f**king us in the ass over and over...
End rant..
Sid
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5731635
Just to clarify, I said there were going to be 2000+ mobile speed camera sites, not 2000+ mobile speed cameras. The justification for their introduction was to monitor traffic "red spots" only, which numbered around 140. Now that they have been introduced under that pretense the RTA wants to increase the sites by a couple of thousand, no biggie......:unsure:
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5731774
oh, so you mean the average driver DOESN'T calibrate their speedo on a weekly basis after they pump up their tyres while abiding by the designated speed limit at all times? :O
Unless your speedo starts eating the gear drive, you don't need to calibrate them, this is why they have to be between 0 and 10% over read at any time for any configuration of tyre approved by the manufacturer.
Most cars over read by at least 3% on brand new tyres. Oh and new to worn out tyres will alter reading by approx 0.5%...
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5732091
What's the bet this one gets settled, with a confidentiality clause, way before September.
http://www.heraldsun...x-1226018034109
Constable Pitman's court transcripts should still be obtainable through FOIA.
She certainly seems to have a case.
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5732470
This, is, horse s***.
How the hell do they intend to keep this in? 1kph? How long does it take the average car to accelerate 1kph over the limit without the driver intending or noticing? 1,2 seconds? More, less? Even factory and after-market cruise controllers sometimes struggle to regulate your speed within 3kph. Do they honestly believe a driver should be checking their speedo LITERALLY every second?
How the F*** is that logical or safe? A slight decline in the road over 2 or 3 seconds could do this. For those whose speedos read within 1 or 2kph lower, and DON'T intentionally speed, you're all about to get f***** hard...
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5732479
SMH states that the ADRs specify a 10% margin for error either way, yet the actual ADRs say that the margin for error only applies that the car is always going equal to or less than the speed displayed on the speedo...
I wonder what else in that article is incorrect?
TL;DR - Sensationalist journalism
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5733410
Two words: GHOST PLATES.
Cameras won't be an issue anymore with a pair of those things on your car.
lulz
http://www.skylinesaustralia.com/forums/topic/61870-ghost-plates-ghostplatescomau/page__view__findpost__p__1167458
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5733487
^ ^ ^ Read Craig's post #22 HOT_R33
Familiar? :rofl:
".....he drives a holden"
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5733504
The new ADR rules of +10% only applies to new cars complied as new cars.
It doesn't apply to any older cars, it doesn't apply to used imports, a car may be tested to have a speedo 3% higher than actual speed when new, give it 10 years and the speedo can go either way, no matter if the car is a Hyundai or an R35. Digital speedos arn't any better either.
https://www.sau.com.au/forums/topic/358645-bang/page/3/#findComment-5733652
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
