Hey,
I realise there is quite a bit of aftermarket suspension info on the forum already but am looking for some aftermarket coilovers for my R34GTT.
Has anyone heard of the custom coilovers selling on Ebay from Perth? The are full custom made coilvers for $810, Made in Taiwan, so similar i guess to the BC brand but for $400 cheaper.
Any info would be great.
https://www.sau.com.au/forums/topic/358653-r34-gtt-aftermarket-coilovers/
Hey buddy im selling Tein coilovers off my R34 GTT which are in perfect condition without any leaks or knocks.. http://www.skylinesaustralia.com/forums/topic/358238-r34-gtt-partsmelbourne/page__p__5723942#entry5723942
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
