hey guys i have been trying to work out the best wat to install my 12"fosgate sub in my 34 :domokun:
i have been looking at the ebay fiberglass ones but i not sure on the sound guality it would put out
i would like it so i can still use my spare wheel if needed but have it so i can do some spirited driving and not have to think about damageing it pinch.gif
any pics of what u have done would be nice cheers
here is a pic of my old sub box with new sub n paired amp i was thinking redoing the floor in chip board and haveing some mounting plates that wing nut it down to the spare wheel cover and mount the cover/ floor to the body same way soem f*kn around to get spare wheel out but atlast i could and my box wont move ?166690_193815617311004_100000477008080_713247_1874290_n.jpg
https://www.sau.com.au/forums/topic/358661-r34-12-sub-install/
I did the same moulded sub enclosure, sounded great, but I had to pour like 4L of sound deadening into it, add dacron as well as make a small bracket and wrap the underside in anti-slip matts.
It did not move at all :)
mount the amp under the rear shelf, on a wooden baffle, either on show or behind the wood so you can't see it
mount the sub in a custom box on the passenger side , where the jack is. mold a box to fit the space, move the jack to the middle of the spare tyre.
all can be hidden and spare comes out without any other mods. nice tight bass, .
eblow box, works but takes up too much space and sounds generic
. you can fit the sub behind the factory panel if you do a custom box. and add another on the drivers side if you desire later. or mount the amp behind the rear panel on the drivers side , totally hidden !!! no metal cutting /mods to mount it
hide or show off amp got it
as for sub box do u mean add some on to the passanger side peace( like half a box ?) for the sub or make the hole bigger to match the sub and mount it to the car ?
if you look behind the trim panel, where the jack is at, the space is just right to fit a 12" sub in a fiberglass box. you can use the little tabs on the metal to mount it. and if desired remove it for track days.
it can fit completely behind the factory panel and a custom grill made to hide it. or show it off your choice. I had mine there but now use a bandpass box which uses that area and some of the space outside the panel, ported thru the rear deck holes. the space is deep enough for most subs and if they work in a sealed box your all good. which the rockfords do
not sure if I still have any old photos , but can show you a photo of the size hole when removed.
anypics would help mate
You could probably replace the thin floorboard into a much thicker one, then use bolted down heavy duty straps to hold your sub+enclosure+amp in place, it will never move. And you can still access your spare wheel in case of an emergency (pssst, or carry one or more of those fix-a-flat cans) That is what I would do anyway.
it will move, when you drive spirited or get hit it turns into a missle.
example
on a defensive driving track day in my work car, a 1.5 litre half empty water bottle in my camry boot , tore the folding rear seats down while latched while on the ABS brake thru the cones test. now imagine a box, amp, speaker, hunk of wood, ripping the rear plate open on the r34 and landing on your lap or the side of the car open like a can opener.
I'll dig up some photos today.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
