cany find real info mation on this damn round about of a way site you wanna know my experience PM me all ill tell you REAL life engine touching blowing up fixing INFO
My head hurts when I try to read this!
On topic though...
The other benefit worth considering is that it takes longer to heat up a larger oil capacity. This is useful for sprints where your at consistantly high rpm and not necessarily getting a lot of airflow. Its been my experience that cooling systems dont work well until your above 80km/h (and in a tall gear, not in 2nd and 7000+ RPM, at full load). Below 80 your cooling is predominatly fan derived.
Im with Steveo with the higher flow and smaller restrictor option too. I like the idea that my bearings area getting plenty of oil flow to keep them cool. I also like that 7 litres of oil stays cleaner for longer compared to a smaller pump.
I know of 2 guys both using n1 pumps and over filled there sumps by 1 litre and still managed to smash there pumps. If money is not a concern I would go for the tomei pump for peace of mind as it has been proven that they can take alot more punishment and being based on a 2jz style of pump you don't hear of them having any problems.
Most of the failed N1 pumps I have seen are accompanied by an equally failed harmonic balancer. At 8000rpm, if you have even the slightest harmonic imbalance, you are going to hammer the living f**k out of that gear. They get larger, they cease to fit in the round hole they are designed to turn in and they start to grab, then they crack or break.
I have seen many people successfully run N1 pumps and standard capacity sumps at the track and not have a problem. I have seen guys with Tomei pumps at the track have problems. It works both ways and it's not always about having the absolute most oil flow you can possibly imagine and all your problems will just waft away. The fact is, the N1 pump flows enough to cope with any amateur type racing events, but is your oil up to the task?
If you are going to run the N1 pump, make sure you are using an extremely high pressure resistant oil that has a film strength higher than any other oil on the market - Royal Purple
It never hurts to have a larger sump capacity and it never hurts to have more flow, at the end of the day, fuel and oil are two of the most important things you need. Who really cares about cost? Another engine rebuild is going to cost you a frig load more.
Another fact is that the materials used to make the Nitto and Tomei pumps are much stronger than the material used to make the N1. They WILL handle more punishment and not break. They have a longer fatigue life due to the material they are made from.
It's the same as the forged conrod argumement - yes the factory rod can handle a shit tonne of hp, no it will not last forever. The fatigue life of a forged rod is much much much longer than the factory rod, and for $600-$800 for a set, why would you stuff around putting old (possibly tired) parts back into your new engine?
If it were me, and I was going to spend 2-3 days a year at the track and 80% of the time it will be a daily, I would leave the sump and put on the N1 pump. If I was going to be spending a day every 4-6 weeks at the track, I would invest the money into a Nitto item. They aren't that expensive and will take a hammering for years :thumbsup:
and +1 on overfilling the sump slightly (0.5 - 1L) at track events. But make sure you have a good catch can setup and check it every 5 laps or so if you can. You'll get to know what your car can handle once you have spent some time out and about
Obviously with added oil/larger sump the oil temps and similar are beneficial to the cause depending on use.
Snowman & Scotsman both ran stock sump'd GTR's for 2-3 years no problems in that department. Motors were stock too and eventually the died but that's what happens @ 330-360rwkw over a hard life. Since then they've both used N1 pumps, as have pretty much all Vic cars. Not one has broken a pump yet. Most motors hand together fine as well (failures are not pump related).
So if you are a bit worried then swap out the gearset. They aren't too expensive and if you get piece of mind then that's covered off.
Comes down to cost really:
Option 1 - 1500 Closer to $750 if savvy Billet gears from JPC.com.au $350 can be used
Option 1.5 - 2300
Option 2 - 3200-3500
I'd also suggest if you are going to go all out on a pump, that you use the Tomei one. It's the only one that utilises a different gearset arrangement similar to that of the 2JZ (never hear of them breaking pumps). It's something I've never really worked out why the other aftermarket pump makers don't use the Tomei/2J style as for a bolt-on pump, it's the way to go.
Thank you R31 Nismoid for the answer above its a very valuable and credable answer
Well said mate. The Nitto will save you the additional expense of having to pull your engine later when the other pump dies. Its the only pump on the market that has not suffered gear failure and each pump is assembled/clearanced checked by the engineer who designed it not some monkey on an assembly line.
you can get a tomei pump out of japan for freakin 1400bux these days, why would you even waste the time on a N1, i mean, you have already spent 6-9k on parts, machining costs, the time pulling it all out, whats the big deal with the extra bit of coin. its not really that much when you think of it, and when it comes down to it, its the rb's weakest link, so why not just put down alil more cash for peace of mind
This man speaks the truth.
I know you explicity excluded the dry sump option but it's worth considering an external oil pump with wet sump. Cost effective, and you can avoid the ^^ guys getting emotional over your oil pump choice.
People just spout a lot of what workshops feed them without knowing any better.
This made me laugh.
Nitto pump and collar, tomei sump baffles and an accusump... would have to be the best set up for the money and ease of fittment....
Otherwise, add a sump extension with pickup.
I wouldn't piss about with an N1 pump on a built engine... Saying that, I have an N1 pump (with no collar) on my thrasher rb25 and have had no problems yet- I do have an ATI ballencer though.
I'm not a massive fan of external oil pumps... the only thing that stops total failure is a thin little belt, with little or no guard...
J.
Pharkk, this turned into a pile of less than helpful vitriol.
The point of the thread was to get some determination on the relative merits of flow rates & sump volumes not to get all the monkeys chucking sh!t at each other.
I don’t want the worlds greatest anything for the sake of having it. It’s like having the worlds hardest clutch which will last forever but destroy three gearboxes during its life. Useless. The point is to get a well balanced set up that works harmoniously over the life of the motor which will, eventually, end up dead. Like they all do.
So far to the best of my understanding:
A stock pump will flow 47litres/minute at 6000rpm.
Various aftermarket pumps have claims to have greater flow rates.
The Tomei pump claims to be 20% higher in volume. To be honest I am not that enamoured with the three piece design.
The Jun pump is claimed to be 25% higher in volume.
The Nitto pump (going on their published figures) is 40% over stock however their number for the standard pump flow rate is lower than the one quoted everywhere else.
The downside of a higher flow rate is the need to have a much bigger sump volume, the knock on effects to the head in terms of getting rid of the oil, the pumping losses, the longer period needed to get the greater volume of oil up to a decent temperature.
The upside is it may give you better bearing life longer assuming you don’t get pump cavitation issues.
Oh and lastly there is nothing wrong with sintered metal. It is just a process used to form steel. Hell BMW used to use it for conrods.
Anyway if anyone can help out by way of confirming the Nitto Flow rates I would be grateful.
Do you mean this data from the website:
http://www.nitto.com.au/products/oilpump-RB.html?category=engineblock
Jun pump data is here:
http://www.rhdjapan.com/jun-high-flow-oil-pump-rb26dett-rb20det-rb25det-16702
Tomei information seems to be all over the place.
Data varies from 56-57 lt/min at 6000 or 7000 rpm depending on what supplier website your looking at.
Or were you chasing actual test data performed by an independant?
The data for Tomei was on volume 22 of new release information from Tomei in Seppoland. Put the flow rate for a stocker at 6000rpm at 47L/min & the Tomei pump at 56L/min.
I wasnt necessarilly looking for independent data just confirmation or otherwise of the Nitto flow rates as the listings they use for stock pumps is at a variance to everyone elses.
Edited by djr81
I wouldn't say the tomei pump uses a gear arrangement similar to the 2JZ style pump? 2jZ pump has a splined gear on the crank, driving the oil pump gear. the tomei pump as a 2 piece inner gear but it still uses the same 2 small flats to drive the pump gear just like any other 26 pump which is the weak point. the gears 'teeth' are slightly different but they are still a gerotor type pump just with much bigger gears with a more suitable material. they are unique in the 2 piece inner gear set-up but still no where near as good as a 2JZ pump. the best option for RB26 is still getting a set of splined gears made up with the inner gear permanently fixed to the crank.
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
