  • Replies 222
Posted Images
Just killed Alduin, thought there would be a bit more of a ceremonious ending? at least a cinematic?
same, I was dissapoint. I was also dissapoint that the absolutely massive guard at the bridge did nothing at all to help fight Alduin, I mean he is 10 feet tall a built like a brick sh!thouse yet does not lift a finger to help! lol
haha yeah that guard was a beast. Admittedly I left the main quest quite late cause I got too caught up with exploring and sidequestions - so easy to do! After I killed Alduin I had to google to make sure I had actually finished the game (so to speak). I really think they needed something to wrap the storyline up.
oh well, onto Rage/STWOR I guess
Ok i'm now Lvl 56 and i think i've sussed a good combo for sneak attacks and general mayhem :)
I've got the....
Nightingale boots (Legendary)
Nightingale gloves (Legendary)
Glass armor (Legendary) with a Health increase bonus
Glass sheild (Legendary) with Fire resistance
The Gauldur Amulet
Volsung (Epic)
I have a ring of Smithing too, but i'm still working on something else in the ring/destruction department.
And the weapons are really only 2.
Glass Bow (Legendary) with Soul Trap..... team that with Ebony arrows and most enemys are taken down with one shot when your sneaking.
Glass Sword (Legendary) with Fire damage.
Getting the 'zoom' in perk on Archery is a good idea too. ;)
Mol the Lioness is who I use if I need a follower.
She's an essential character aka can't be killed.
Mecurio is also good as I'm all about dagger/bows and he just stands there and blasts magic. Hooked him up with a Dragon Priest mask with 100% Magica Regen and he went apeshit with the Magic.
yeah the carrying is the major perk but once you get shitloads of gold theres not much point hoarding items.
I've finished the main quest, are there any other major quests you guys would recommend I do before moving onto SWTOR? The one with the volsung masks etc looks interesting?
Jizz what's his face is where its at.
Hook him up with daedric armor and -100% destruction spell mana cost enchantments. Summon two storm thralls and run around with your nightmare horse, you become a walking army.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
