  • Replies 222
Posted Images
Well finally up to level 49, on the main quest now thanks to your help i know which is the main quest now (one with the dragon squiggles next to it in the journal)
I have my enchanting and smithing up to 100 and most areas filled. Got my daedric bow up to 196 points damage which is beautiful! most distance shots kill in one shot, however if they are too close only takes off halve the amount.
Was looking on you tube the other day and saw a guy that had his alchemy skill maxed and created a smithing potion at 120% so his weapons and armour where ridiculous!
I'm at lvl 57(i think) & still only up to "Alduin's wall" quest lol
haven't played in a while as I'm currently Overseas
This might have to take a backseat to Mass Effect 3 as I get back to aus a day before it's released, yeahh boii!
Just on normal setting at the moment, do you get any extra bonuses etc when playing master? ie more XP points when killing?
Dunno, but it will make it a little more challenging than just walking through blasting everything. Much more enjoyable :)
This game is evil. I remember playing for hours on Oblivion for the PC and I only got out of my apartment for food and drinks. Sometimes the whole week would pass by in a blink. If I hadn't a job now, I think I would be doing the same on Skyrim. Great evil evil game :thumbsup:
Had a shot at this a couple nights ago...I haven't played since because I can see me getting addicted to killing innocent villagers, GTA style...and that's before I start playing it properly.
Yup just finished it, completely agree with what others had said. I even had to you tube the ending to make sure i had just done the ending (hope that makes sense what i am saying)
Still have side quests etc but i think for now the last few months have been taken up enough by skyrim.
Going to play BF3 but am reading they are talking about skyrim add ons, no doubt similar to the Fallout franchise, in which case I WILL BE BACK :-)
is this game really that addictive ?
Yes. 192hrs of game time and counting (albeit a lot slower now)
Almost as addictive as UFO: Enemy Unknown back in the early 90's
Edited by iamhe77
  • 2 months later...
I've not played for a while, been 2-3 months. Back into SC2 atm...
I wanna finish off Skyrim as I never really finished Oblivion properly, there is massive unfinished business :D
Hopefully though when i do go back to Skyrim they have fixed all the buggy as shit quests, I had a lot of outstanding ones.
I also wanna upgrade PC so i can turn on ALL the fruit and a few extra community enhancements etc to really go nuts
    • Ok sounds good. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
