  • Replies 222
Posted Images
  • 3 months later...
thread revival sorry,
im getting back into Skyrim, though am looking to make the switch to PC.
Will be building a new PC in the next few months, quick question:
will Skyrim run on Windows 7 32-Bit???
its my understanding that 32 bit caps the amount of Ram being utilised at any one time.
though, i've got a spare copy of Win7 32 so if possible, id rather not buy another copy of windows
  • 1 month later...
DLC on it's way.
http://www.bit-tech.net/news/gaming/2012/11/06/skyrim-dragonborn-revealed-and-set-for-rele/1
Just wish they'd fix all the bugs before releasing more DLC.
Got the Dawnguard DLC and I'm stuck cause someone isn't somewhere and there is no way to fix it.
Better yet, realease console commands for Xbox.
  • 1 month later...
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
