biggrin.gif ...for a second you had me going "oh crap...", but then I remembered that the compressor housing could only face one possible way (and I did move the compressor housing to that position!) and that way just wasn't compatible with straight linkage. But no you're absolutely right, I don't wanna do this at all, I'd rather chill with a cup of tea and a book hehe.
But yeah, it's a bit different when stuff can sit for as long as it takes. Sort of "un-forced", one goes there when in the mood for it etc. Be it at the cost of forgetting and relearning. I'm refurbishing some alloys for my own car, 2/4 done, it has taken 3 years so far. thumbsup.gif
