Hey guys.
does anyone know how to use Discreet Combustion or Alias Maya 5?
i've posted on those graphics forums but the only responses are from those comp./graphics geeks with their technical bullsh/t ........
theres tuts on the net about Maya....but man.....what the hell do u do with combustion??? finsihed artworks look bloody good from users of combustion... but how do u use it? and what is it for??
anybody kno???
https://www.sau.com.au/forums/topic/35879-help-with-graphics-programs/
