Hey guys,
As the title says Im looking for a 180sx/200sx Or 32/33 skyline.
Really looking for a 180sx over the others but if you have one of the others let me know.
I have a budget of around 5-6k atm the car can be in any condition as long as it runs & drives.
Cheers,
Chris
https://www.sau.com.au/forums/topic/358803-180sx200sx-or-3233-skyline/
