As title says In the last month after turning the car on to warm up and on 3 occasions when I turn the headlights on the whole car shuts down.
I then have to turn ign off and start again and its fine.
I have a 1 year old battery which I replaced with a bigger one. I dont think its a battery thing.
Has anyone else experienced this before?
never heard if it before........ something to consider even tho the likelyhood isnt great.
all M35's have an auto/park/low beam setup ?
if so could the auto selection be shorting out on something ie: you had foggies and they cut the wires and they are shorting out...... but this should blow the fuse not mess up the ECU.
also the power consumption of the headlights shouldnt have enough of a serge to make the car stall, but in saying that maybe a coilpack is playing up? (just another idea)
also check ur relays there could be a damaged one.
maybe an auto electrician can tell you more............. i usually play with 240V not 12V :)
cheers, Theo.
cheers, Theo.
I usually play with anything upto 275000V also. Yes your right I would blow a fuse if I had a short.
I dont think its a coil pack yet because its only shut down when the lights are turned on. But I am thinking something HV. I think the headlight transformers are breaking down to earth on the HV side and the ecu isnt liking it.
so unplug the headlights at the headlight unit one at a time and test by turning the switch on.
see if it only does it with one etc. you appear to be a sparky, use your head :P
if it still stalls with both headlights unplugged, its somewhere in the switch or the loom.
when they automatically turn on, does it stall too? if not, its not the headlights, its probably the switch. i have a spare if you think thats what it is
Sounds like a bad earth somewhere, I changed the battery terminals over to the larger ones for a better connection and fitted earthing wires around the engine bay, do you have an earthing kit? Check all the earth connections on the engine as they are known to corrode.
The BCM under the inside fusebox controls the headlight switches, I would think it then goes to the relay board behind the battery. Check all the plugs on that too.
I smell what your cooking. The problem is it has only happened 3 times in the month I cant fault it when I try it again a few times. I hate finding intermittent faults. I will try leaving the lights on auto and see if it does the same thing over time.
Also it dosent just stall it goes completely dead all dash lights everything goes off and stays off until I turn ign off and on.
Its like a relay trips off and is reset when car is turned off.
Ive checked all the earths and yes I have an earthing kit around the engine bay that I made up. I think this has only started since the turbo rebuild. But I think the problem was there before I took the engine out.
I havent had any thing else play up yet but the problem is like if you unpluged the BCM and then nothing happens.
Ill have another look around that area and maybe ill unplug the ecu again.
Brad, another thing to look at is your ignition barrel. I had a bad connection in the ignition barrel so that all the accessories would turn off at random times. Turned out to be a bad connection on the barrel so that if the key moved slightly power would be cut.
Cheers
Andy
Engine out for a turbo swap? Who told you that was a good idea? :)
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
