  • Replies 337
Posted Images
he says wed, and infact, the rear bar is coming today, so, well, i'll bug him daily
HAHA, if its not ready by then i'll just rent, its covered anyway.. a getz that is =(
Rushed panelbeater = rushed paintjob. Don't do it!
nothings been posted yet but usual pre meet spot as at the monash uni carpark in clayton. feel free to post something up. or im sure someone will
fair enough.
im not planning a pre meet. someone else can lol
lol charlie dont think it matters if you still have your 34 or not. have had the chaser for a year and attended heaps of SAU events.
Haha I was kidding! 'Sif I'm gonna let anyone tell me I can't show my love for Skylines :P
Will organise a pre meet mmhmmmm
it might be kinda far for the northsiders and westies and all.. i reckon, personally i dont mind. but you know...
oh nah i meant just for the SE peoples to cruise up to the meet spot
lol yeah. Same here.... Car not ready yet either, just called chasers. Mowed lawns, paid bills, cleaned up house, done shopping, ran out of bourbon..............got some more............. now the long wait till footy 2night. Might break out the ps3.... or clean up the pool shed & get back into that
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
