  • Replies 70
Posted Images
they do serve a purpose
looking f**king mean :devil:
+1
Don't forget there real name either....."Rub Guard's" for those times when you have to run a stupid f#$ker off the road but don't want to scratch you paint!!!ph34r.gif
this is the reason why I bought an ARX - when I get the $$$ i will get an axis front bar and rear skirt
If you aren't going with the FRP kit, you may be quite surprised when you find out how much Nissan charge for the bonnet ornament (and it's backing)
On an ARX?
I think you are confused.
On an ARX those flares look as good as they do on this
Ooh yeah, real mean.
hahaha cam even that holden looks more mean than your princess blue coloured animorph whistling.gif
haha, but I am not the one that thinks or is trying to persuade others that their car "looks mean", am I?
Funny thing is that even if you colour-code the flares, you still have to deal with the gay old man, tan leather that is inside the ARX.
Unfortunate, but true... ARX = ugly inside and out
Sounds like venting on C34's has taken a turn onto ARX vs RS/X !!!:happy:
I think ARX plastic fantastic look odd. The Mrs agrees "plastic wings..." she reckons.
They peel off at high speed, they make your rims look gay cause of offset fail, and attract people to bump into them.:P
come at me NA brah! lol
FlAir= needs more aggressive offset. Doing this right = win. Doing it wrong= car wil look like a spaceship
Has anyone got pics of an ARX with guards bumper, skirts etc colour coded? I was thinking of doing this at some stage but didn't know if you would have to put some sort of primer on first to smooth out the "texture" and whether it looks OK or not.
Also what offset is aggressive? I am looking at some wheels (down the track) 20x8, they come in +30 or +45.
AND by the way. the tan leather of the ARX is the best part!!!! It's why I went for an ARX....... then again, I am old (not in my 20's anymore)
Rudy, (can't remember his forum name) colour coded the body moulds on his silver ARX, saw it when we were at Eastern Creek Drags a while back; works quite well, but his flares were not shiny because of the textured surface of the plastic. You'd need to do a fair bit of Hi-Filling to smooth the surface to give an nice gloss.
As for offset on an 8" rim, you want +30 offset at absolute minimum. You could go +25, even +20 offset on an 8" rim with a 245 wide tyre, without any clearance issues or guard rolling.
Edited by Daleo
theres a white one going around but it looks like ass. failed attempt i think.
I think it's really dependent on colour; Black would work fine, White; a bit like a fridge. Silver looked ok, but I've seen a gold one, and I'd rather poke out my eyes than have to look at it again; bloody atrocious! Also as others have said, you'd have to butcher the bodywork underneath the plasitc so you can get the wheels out far enough to fill the guards properly.
Edited by Daleo
Lol....nothing wrong with my offsets NA boy!!!!.... Fill the guards quite well actually.... My offset would however look shit if I didn't have the rub guards.....lol!
And what's all this ar-x jealousy from the guys that own poverty packs all of a sudden!:P
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
