I think it's really dependent on colour; Black would work fine, White; a bit like a fridge. Silver looked ok, but I've seen a gold one, and I'd rather poke out my eyes than have to look at it again; bloody atrocious! Also as others have said, you'd have to butcher the bodywork underneath the plasitc so you can get the wheels out far enough to fill the guards properly.
agree.
i wanted to do mine, but theres really no going back if it fails..
i was thinking more of doing a matte paint finish on the car instead.. hmmm
  • Replies 70
Posted Images
Lol....nothing wrong with my offsets NA boy!!!!.... Fill the guards quite well actually.... My offset would however look shit if I didn't have the rub guards.....lol!
And what's all this ar-x jealousy from the guys that own poverty packs all of a sudden!:P
I like to think of mine as a "stripped out, performance lightened version" thank you :nyaanyaa:.
Wouldn't mind a sunroof some days though...
hmmmmm.....pinch.gif......maybe....damb it!!!!......you need to earn the performance part though!cheers.gif
come at me NA brah! lol
NA not too much longer!
Also what offset is aggressive? I am looking at some wheels (down the track) 20x8, they come in +30 or +45.
Fail, and Fail. Daleo is right - an 8 inch would be a +20/25 Use an offset calculator, and look at some setups and calculate to see what would fit best.
Please please please don't go down the Chromie 20" path....:spank:
go more aggressive with the wheel
19x10 and 19x10.5 with +20 offset
like to see that.
This is
Work Gnosis GS1
Front:
20x8.5+18 (225/35/20)
Rear:
20x9.5+20 (245/35/20)
Fit another inch in the back....? You'd be Mexican.
cant have staggered in AWD...
+1
Its a pain in the ass but Can't do it.
Edited by PN-Mad
like to see that.
This is
Work Gnosis GS1
Front:
Rear:
+1
That car is a fail to me! It looks awesome, but....
I want a car I can actually drive, this is much more important to me than my car looking 'tuff' in a photo. I definitely don't want any scraping at all.
Wouldn't get up my driveway in that thing :O
Edited by jidge
+1 on that.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
