Posted Today, 09:16 PM
Looking for the right part choices for my up comming rebuild
im going for the standard rebuild and will go for this kit
Nissan gasket kit
It includes
- Engine Repair Gasket Kit
- Genuine Nissan Parts
Kit Contents:
- 1 x Tube Liquid Cement Sealer
- 1 x Sump Washer
- 1 x Head Gaskets
- 3 x O-Ring Vacuum Canister
- 2 x O-Ring Vacuum Canister
- 4 x O-Ring Vacuum Canister
- 1 x Crank Rear Oil Seal
- 2 x Cam Seals
- 12 x Valve Stem Seals (Exhaust)
- 12 x Valve Stem Seals (Intake)
- 1 x Rocker Cover Gasket (Exhaust)
- 1 x Rocker Cover Gasket (Intake)
- 1 x Front Crank Seal
- 1 x Intake Manifold Gasket
- 2 x Exhaust Manifold Gaskets
- 2 x Turbo Inlet Gaskets
- 2 x Turbo 4-Bolt Gaskets
- 2 x Dump Pipe Gaskets
- 3 x Turbo Inlet Gaskets
- 1 x Oil Filter Gasket
- 1 x Oil Pump Gasket
- 22 x Banjo Bolt Brass Gaskets
- 1 x Oil Drain Gasket
- 2 x Brass Turbo Oil Inlet Gaskets
- 1 x Oil Filter Housing to Block Gasket
- 1 IAC Valve Gasket
- 6 x Throttle Body Gaskets
- 1 x Cam Angle Sensor Oil Ring
- 1 x Water Temp Sensor Gasket
- 1 x AAC Valve Gasket
I would substitute the nissan head gasket with a cometic or similar
And some of those metal t/b gaskets
and will get ACL bearings
Now i want a crank collar for obvious reasons but i will need a 33gtr oil pump to do this right (i have a 32gtr)
Ill be using standard pistons & rods if they are still ok
and will be cleaning up the head
Ill be having a very experienced friend doing this with me doing the smaller things like cleaning parts etc
may get a baffle but cant really see the benefit with my drivng style
Any other bits to order that i may have missed?
Thanks
https://www.sau.com.au/forums/topic/358930-rb26/
Hey Jase, if you're not going over the top then a stock head gasket is pretty good. I have some HKS metal inlet gaskets you can have if you like- they're used but in good nick. I'm also rebuilding a 26 at the mo so if you want to come and have a squiz give us a yell.
Block restrictor a good idea. Your friend going to help check clearances?
Also, are you using stock turbos? Porting the stock manifolds and turbo housings is a good idea while you've got the opportunity.
Happy to get together and chat if you like.
https://www.sau.com.au/forums/topic/358930-rb26/#findComment-5734485
Hey mate how you been?
My mate will be doing all the work ill just be helping helping and learing where i can
I have 2860’s with stainless mani’s
Is it possible to use a restrictor with a stock oil pump or will I need to do all the other jazz also?
https://www.sau.com.au/forums/topic/358930-rb26/#findComment-5735668
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
