  • Replies 56
Hmmm i dunno about those racv test's.I sold a car once and i kid you not the car was imac.Now the mew owner got a test done after he bought it.....The car was an Isuzu MU,Now they said the wastegate is jammed on the turbo charger...now if its jammed open..it get no boost..now if its jammed shut it will overboost and **** itself....now after he had it done i checked the car and the report...they said the trans had leaks...there wasnt and leak at all...there was a small amount of seepage around the rubber hoses but it wasnt leaking...and the turbocharger OMG...i hooked up a vacum gauge to the car and stuck it in park and stood on the brake and wham it went to 8psi then cracked off and held steady......they also said"essesive black smoke"I got all the stuff check by allfleet deisel services in airport west and they laughed at the report..."nothing is wrong with it"the guy said.And to top it off when the guy took it in to get tested the radio worked and when he picked it up.....it didnt.I called them and the guy that done the report wouldnt speak to me and the guy on the phone said "oh well the wastegate musthave unjammed itself" I just told them i didnt think they knew what they were doing and the guy is very upset with them coz we had it double checked and there is nothing wrong apart from the radio prob which they caused....make your own mind up but id be getting a perfomance place to check it before racv...
It's clean...completely clean. No mods. Done about 42000Ks but I figured it's been knocked back. But had my mechanic go through it and it's in A1, the trims all fine etc. Only thing is the hicas light shows up occasionally. And I hate those damn rims...I'd be quite happy to get a stock 2nd hand set if anyone wants to sell. It's got a GTR spoiler too..which kinda spoils the understated look.
I'll try and get the web space tonight to host it up. Thanks for all the advice guys!
Red32 (Ross), a friend of mine is also looking for a 32, I'll pass the message to him. Although, I think he's looking at about 15-16K too. Is your car still up for sale?
Hi guys,
Just some questions about my 32 that I'd like to ask. I'm still a newbie here, so forgive my ignorance.
1. What the heck is a Type-M? What's so different between that and a standard GTST?
2. With my fan switched on (air-con is off), I notice my revs at idle keep varying between 650-850. And the tone of the engine note is variable. However, with the air-con on, it's at 900 and it stays constant. Why is this so? Anyway I can stop the variations? Do an ECU reset?
3. Where can I find a knowledgeable skyline or nissan sportscar mechanic in Melbourne? Any recommendations?
Type M = Turbo, Type S = Non Turbo (roughly, there are the exceptions
The revs are higher coz there's more power drawn from the engine (alternator etc) when you switch the AC on. Check it out, put a stereo in and turn it on, put your demisters on, put your fog lights and headlights on and your engine tone will change. All cars do it, some just do it more noticably than others. You could stop the variations by using a 2nd batterey to operate all accessories off and using a trickling circuit to trickle charge the battery only while the car is in motion... or you could put up with the tone changes. Personally I use the tone to check what I've got on.
Trying to find one myself, but meggala recomended sum dude in Cheltenham, or there's Dean, but I dunno if he does servicing. Ask them for more details.
Actually...the revs vary when I have no aircondition on. So while it's at idle...the tone changes quite frequently. Isn't that quite disturbing :D
Will check out ICEPERFORMANCE.
The thing is...my car looks different from those with a Type M bodykit. Is there such a thing? I'd like a body kit like that...not too ostentatious :D
my one has the Type M kit does it look like that?
u can also get Type - X which was the CA18 4 cylinder engine, the Type - XG which was the RB25DE and i think thats about it...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
