As a close friend of Wardest I can tell you that he is still alive and kicking hard!!
I was at Two Tribes with him and will be seeing him again this weekend for a big night at Hard Kandy.
Unfortunately I think he is inundated in work so doesn't have much time for the forums anymore.
You guys are gonna have to start your own controvertial threads now to entertain others :)
https://www.sau.com.au/forums/topic/35906-wheres-wardest/#findComment-717437
TT was farking maaaaad!!!! I was there from 7-7 and I can tell you that I feel fully exercised for the next 12 months. The music was pumping, the people were pumping and everyone was having a great time.
Can't wait for next year!!
GT-400R, Wardest was the one in the dark blue phatties with flouro green shirikin stars on the front and was wearing a dark blue visor. Don't think you saw him coz everytime I saw you, I was going to meet him...
https://www.sau.com.au/forums/topic/35906-wheres-wardest/#findComment-717905
You guys are gonna have to start your own controvertial threads now to entertain others ;)
Alive n kickin is good dave :kick:
:P
Hhmm.. so he's a busy man these days. That aint so good then!
I guess this is the first 'thread' of any moderately amusing nature since he's been gone. It's just not the same without him.
https://www.sau.com.au/forums/topic/35906-wheres-wardest/#findComment-717947
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
