$17,700 ono
1994 Gunmetal Grey Nissan Skyline GTR
RWC supplied
Reg til Oct 2011 (WBU826)
104,000 kms
Imported Sep 2007 with 96,595km on the clock and in original condition (except for the wheels)
100,000 km timing belt and water pump service performed upon import.
Upgrades (all less than 5000 km old):
Apexi PowerFc
Turbos Garrett 2530-5
Xforce MetalCat
Nismo AFMs
Nismo Fuel Pump
Sard injectors
Tomei PonCams
Tomei Cam Gears
HICAS lock
Jaycar amp
JVC Head Unit
Alpine VR split system
R34 GTT Rims sprayed Soft Mica Black
Car lowered professionally
Tuned by Ben at Race Pace.
Overall condition is very good. Kept garaged and clean. No major accident damage. A scrape on the left front quarter and an orange-sized dent in the rear left quarter. Had rear and bonnet badges removed for stealth. Electrics all fine except for a globe in the gauge set and A/C probably needs regassing due to disuse.
Car is in Maribyrnong VIC, but can also view in Caulfield by arrangement.
Please note pod filters and shield pictured have since been reverted to factory air box.
Also note I have most of the original parts including turbos, which I would be happy to throw in if wanting to restore back to original condition.
Will consider swap for a baby-mover, preferably a Toyota Caldina GT4.
Please PM me if interested.
https://www.sau.com.au/forums/topic/359077-for-sale-1994-r32-gtr-vic/
(Sorry admins, not sure how to edit original post. A few have asked me about kw so I have added it)
$16,900 ono
RWC supplied
104,000 kms
298 rwkw
Apexi PowerFc
Nismo AFMs
Nismo Fuel Pump
Sard injectors
Tomei PonCams
Tomei Cam Gears
Xforce MetalCat
Stainless Front-pipe
Stainless Dumps
HICAS lock
Jaycar amp
JVC Head Unit
Edited by wrysky
(Sorry admins, not sure how to edit original post. Corrected kw figure and added TEIN adjustable suspension)
$16,900 ono
RWC supplied
104,000 kms
289 rwkw
Imported Sep 2007 with 96,595km on the clock and in original condition (except for the wheels and suspension)
Upgrades (all less than 5000 km old except suspension):
Apexi PowerFc
Nismo AFMs
Nismo Fuel Pump
Sard injectors
Tomei PonCams
Tomei Cam Gears
Xforce MetalCat
Stainless Dumps
Jaycar amp
JVC Head Unit
TEIN Adjustable Suspension (Super Street?)
HICAS lock
Front Strut brace (not fitted)
Edited by wrysky
  • 3 months later...
(price lowered)
$16,500 ono
RWC supplied
104,000 kms
289 rwkw
Apexi PowerFc
Nismo AFMs
Nismo Fuel Pump
Sard injectors
Tomei PonCams
Tomei Cam Gears
Xforce MetalCat
Stainless Dumps
Jaycar amp
JVC Head Unit
HICAS lock
  • 1 month later...
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
