Thought id share my project for both sharibg experience and gaining some.
I have a s1 4 door 33 that started life as an automatic 2.5t. It was converted to manual and imported in 2000. Since then whilst in the hands of the previous owner it snapped a rod and an epic 30det was built for the car. After several years of bad luck and skids the previous owner decided to part it out, i brought the rolling shell minus box, engine and radiator.
I have a s3 manual gx 31 that is my daily and shortly to be my donor car...
Next week im putting the rb30 box and engine into the r33... As a strictly budjet project.
Ill be posting up some pics as i go as well as sharing pointers about.interchangability that i come across duribg this rare and retarded conversion... With 4.36 diff gears however im sure it will be interesting.
https://www.sau.com.au/forums/topic/359101-the-4-door-gts25t-with-an-rb30e/
aha , it was you that bought it! , nice :) , are you planning on rego? might want to check with authorities before putting the rb30e+t? in to make sure it can be done . A friend of mine tried putting an older motor in a car he was building and found he couldn't get it passed for rego ( just a heads up :) )
Technically patrols came with rb30s untill slightly after the r33 was made... So it should be ok on paper... Its currently regoed with a 25det. I dont plan on changing it to be honest. If push came to shove it could be engineered without a problem. I had an engineer approve a 95 vs commodore with an rb25det s1 engine from an earlier 33.
Conversion starts on sunday but ill put up some pics soon.
At this stage i dont think ill turbocharge however ive been dreaming of supercharging, response and torque is the aim here but so is keeping to a very low budget. Have to see if it spins the 245`s on the back lol.
Ahh yep , didn't know it was still rego'd , all sweet then! :ph34r: . rb30 will love 4.3 diff gears and 245s! , i doubt you'll need a supercharger for response . I was gunna buy this car myself but couldn't find anywhere to put it (when i did it was too late :P ) . what you doing with the leftover bits of r31?
the left overs are being given to Phil Parnell for payment, hes the one doing the conversion for me
conversion under way:
exhaust, im please to say, lined up perfectly
gearbox cross member was not interchangeable
tail shaft was not interchangeable
r31 radiator does not fit, its too tall.
all ancillaries bolted up, inc air con.
wiring yet to be done
Ha ha ha... nice one.
Throw a lumpy cam and some more compression at it (along with the right exhaust) and get a really unique sound for a 33.
Good luck
Justin
Edited by XRATED
Updated: r33 n/a tailshaft fitted, so did the standard r33 gearbox crossmember. The wiring was litterally 4 wires at the ecu side using the whole r31 engine loom with the r33 relays. Ended up chopping off the r31 altenator plugs and using them on the r33 body loom.
I have not hooked up the speedo or tacho yet but i have a jaycar speedo corrector mk2 that im hoping will work to correct the change in diff ratio.
Ill post up some vids and pics over the easter break
update: speedo worked with the speed correcter, massive 40% difference due to gearing! lol simply used 12v+ from r33 gearbox loom, made an earth and then ran the signal wire to the cabin to the adjuster and then straight to the back of the dash. FYI, for those using a Jay car speed correcter MK. 2 with an r33 you need to use the 8.2v JP1 setting and then use the AC JP5 setting... should work a treat!tacho cannot be driven by the stock tacho output from the r31 ecu, i will most likely piggy back it off the CAS or i will make some kind of relay style circuit to convert the signal to run the tacho
Im happy with how it performs. With the short gearing its nice and zippy. Feels very flat but as soon as you stomp it the powers there. Took down my mates auto s-vz no worries. Im thinking of keeping it na but tuning it to push the peak torque up the revs a bit just to make it a bit more powerful. First thing ill be doing. Besides a general tiday up and maintenance is a nistune ecu and some dyno time.
Before you get it tuned bang a cam and extractors in it.... One of my r31's many many many years ago, we threw a cam and chip (allready had extractors) at her and she really came alive.
I recently saw a shot on here somwhere of a rb25de manifold with twin tb's.. Similar to the 5lt walkinshaw manifold. There may be something in that too.. I'd be tempted to go two 50mm vg30 tb's. Or even try adapting a gtr intake set up to the 30??? Very unique either way.
You comming to the track day?
Cheers
Justin
Edited by XRATED
that looks a whole lot like Skitr31's engine bay! 150rwkw running an rb25det tune... noice
at the moment cash is tight so i wont be coming to the track day unfortunately.
im unsure what way to go yet, boosted, n/a 30e head or n/a 25de head... either way the car needs a tidy up before i start blowing wads of cash on making it go fast!
30e+t , if your aim is under 300rwk , nice and simple (and cheaper )
That's what I said at the track day... today.
Nice simple precision billet 5557 with wastegate and manifold adapter. Nistune, VL-T injectors etc...
J.
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
