2 sets of RE55s Semi Slicks for sale:
Both sets have a few track days left in them, however one set is a little less worn than the other, and has some camber wear (still fine to put on the rear). Size is 255/40/R17 and even when they reach the wear indicator are still far better than road tyres for grip on the track - and these are CHEAP!!
Better set: $400 ono
Other set: $300 ono
1 Set of 4 Maxxis Street Tyres 255/40/R17 $200
2 of them are around 50%, the other 2 %70. They have a little superficial tread damage due to HP and the dyno! This doesn't effect the tyre though.
R33 GTR Wheels $1200 ono
Sard 700cc injectors $550 only 3500kms fitting available
R32GTR REAR brakes setup for Track $250ono
Rotors are in great condition (GENUINE NISSAN), Mega $$ Endless Brake Pads, Braided Lines, Brake Ducts included and calipers rebuilt with seal kit only 1500kms ago.
Fitting available for $50.
Reason for sale - New big brakes on the way and the 17 inch wheels / tyres won't fit :cheers:
Pickup preferred or buyer to pay / arrange postage
Lowballers ignored
PM's replied to - I will be away racing this weekend and will reply to further PM's on opportunity or Monday.
Cheers,
Andrew
Better set: $400 ono SOLD
Other set: $300 ono SOLD
R33 GTR Wheels $1200 ono SOLD
Rotors are in great condition (GENUINE NISSAN), Mega $ Endless Brake Pads, Braided Lines, Brake Ducts included and calipers rebuilt with seal kit only 1500kms ago.
Lowballers ignored
    • Don't think that can fit in physically. Are you referring to this?    If it happens again, I'm going to get the nismo ones.
    • I bought the 1/18 scale celica and nsx from Justin and they are very detailed and good quality. I will definitely be interested in others in the series as they come out
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
