What is the standard dwell timing on the RB25DET coil packs? And how much would this differ from Series 2 commodore coilpacks with Eagle 9mm leads?
People have done wasted spark setups and run them fine... yet when I do it and it doesn't run right I get critisized and told to put it back to standard.
I don't really like the design and want to run external packs since I think they would give extra parts. I have tested the spark, it has spark on all 6 cylinders. I have replaced the igniter, replaced the AFM... all runs the same. Turned the CAS and injectors fire, there is fuel pressure in the rail.
ECU gives me code 55.
Car starts and idles very poorly with the wasted spark setup.
The plugs foul up relatively quickly. I cleaned them with carby cleaner and sanded them shiny, set 0.8mm gap and still starts and idles crap straight away.
Next step be check with a gauge for vacuum leaks? I have looked over and all the hoses are connected properly from what I can see. Will a crack/split in a intake/vacuum hose make it run really rough, and make it not want to idle properly and not rev at all under load and stall?
Timing has been set to 15 BTDC with a light last week, CAS marking is in the same spot as it always has been.
What would be my next steps other than changing back to standard coilpacks? (Because this is going to cost me $300-500 just for loom and coilpacks)
https://www.sau.com.au/forums/topic/359108-dwell-timing/
You have obviously f**ked something up. Most likely a wiring issue but who knows without looking at it. It amazes me what big things untrained people can miss and or overlook. Car should run fine with std dwell settings. Time to tow it to someone that knows what they are doing.
https://www.sau.com.au/forums/topic/359108-dwell-timing/#findComment-5735855
lol it's not a old holden 6 . check for induction pipes cracked/slit or not properly connected , sounds like limp mode or you got the wiring wrong?
So a little slit in the induction pipe will cause it to run like crap and not be able to drive without dying in the ass? I didn't think that sort of thing would make that much of a deal...
Wiring is perfect to digrams I have seen and tested for continuity with a multimeter. I understand the principle on how the spark setup work and which wires go where and why. I'm thinking I've rooted a hose or something somewhere around, since it has the same symptoms with the standard loom and coilpacks.
Edited by Justlikemusic
https://www.sau.com.au/forums/topic/359108-dwell-timing/#findComment-5735937
why is every one changing to wasted spark set up? oem coil packs at race track temps with big boost and high hp can work well.
If your 15 - 20 year old coil packs are failing its because they are old and your car hasnt really done 80 000 km's its done 200 000. NOT because nissan designed a bad ignition system. Its a high performace engine.
they have been delivering spark to a boosted chamber for at least one decade.
your car probably hasnt done what the odo shows.
your car probably sat at a yard or warf in japan for months on end whil everything went brittle.
the copper in your coil pack harness is old
ive had great sucess with oem coils in multiple engines/cars
yes rb engines do suffer from misfire sometimes but there is no prob with coil on plug system.
https://www.sau.com.au/forums/topic/359108-dwell-timing/#findComment-5736052
Surely though the Commo coilpacks put out a fatter spark, run cooler and have less problems after I have upgraded them to MSD units... Car has done 132,000km's actually. I bought the coilpacks for $10 which were in good nick, mates rates... and the leads I had from my Falcon sitting here which were expensive too. Didn't want to spend $500 on splitfires when I could fix it for $40 worth of cable/brackets/wiring/plugs. Im sure the problem is vacuum hose split somewhere.
https://www.sau.com.au/forums/topic/359108-dwell-timing/#findComment-5736081
So; you have a series 1 motor with the external ignitor pack and have connected the output of that to the commo coilpacks which presumably have built in ignitors. Off the top of my head i cant tell if that will cause a problem, but have you thought it through? Do you understand how transistors work?
https://www.sau.com.au/forums/topic/359108-dwell-timing/#findComment-5737534
^^^ are you saying to try it without the ignitor and just wire the output of the ecu straight to the como coil packs?
like above but it may not be an issue with the spark at all, maybe there is something causing the car to run excessively rich?
What ecu are you using
https://www.sau.com.au/forums/topic/359108-dwell-timing/#findComment-5737591
try another afm, they are very temprimental, even if they are sitting the wrong way they can make the engine run like crap. try moving the afm around or something
Tried that already too...
S2 Commo coilpacks sit on top of the DFI module which I assume is their "built in ignitor". This has been removed so they are a basic twin tower coil. Same plugs and wiring as used in the "RB20DET Commodore S2" DIY writeup, except with S1 Skyline harness wiring.
Using standard ECU...
https://www.sau.com.au/forums/topic/359108-dwell-timing/#findComment-5737665
Without applying any brainpower, that would seem the most obvious way to set it up to me. I'd want to make sure that the commo and nissan ECU's use similar signals to the ignitors before doing it tho.
https://www.sau.com.au/forums/topic/359108-dwell-timing/#findComment-5738128
I *think* you can tell if it has a built in ignitor by the number of earth connections on the coil itself. For some reason they seem to use separate earths for the signal and power circuits. I dont know enough about electronics to know why they bother doing it that way.
https://www.sau.com.au/forums/topic/359108-dwell-timing/#findComment-5738136
Coilpack is grounded via the bolt hole (there is a contact there) - other connection is straight power. Maybe sending power through a signal cable isn't ample to provide good power to the coil at a quick instance.
The DFI module which the three coils sit on (with spade connectors into it) is the commo's igniter. You remove this and put spade connectors on the bottom of the coilpacks and run it with the skyline setup.
Tomorrow I'll get new plugs for it... some BKR6E's and will resize the spark leads so they have a very very tight connection over the spark plug. At the moment they feel like they clip on and are a bit loose.
https://www.sau.com.au/forums/topic/359108-dwell-timing/#findComment-5738207
Possibly a fouled O2 sensor?
I changed extractors on my Falcon a year ago and the new O2 sensor was shot... car run like ass. I guess it can't hurt to keep buying these bits and work out what it is. I'll have spares in the future and I plan on keeping the car for some time.
https://www.sau.com.au/forums/topic/359108-dwell-timing/#findComment-5738976
Replaced the plugs, started it up and idled bad straight away. I have a replacement O2 sensor to go in it tomorrow when I get a suitable spanner to remove it.
I disconnected the o2 sensor and it idles the same... will this be any indication that it has gone bad?
https://www.sau.com.au/forums/topic/359108-dwell-timing/#findComment-5741872
    • Good news!!! Changed the O ring today and Iโ€™ve got the โ€œpssshhhhโ€ back when I open the fuel cap ๐Ÿ˜‚๐Ÿ™Œ๐Ÿผ๐Ÿ™Œ๐Ÿผ It was 100% the O ring because that bloody thing was inside the fuel tank ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚ Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But sheโ€™s running!!! โค๏ธ
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though egย https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
ร—
ร—
