Engine was built by a shop down bris, usual rb30, 25de head, spool rods, mahle pistons
its dont about 3-4000km's and she's spun a bigend.. going by the colour of the rods were thinking oil starvation? whats everyones thoughts...
tune was 360rwhp on 13psi with a t04z, engine was run in on the dyno and had been running sweet
Edited by 32rrr
https://www.sau.com.au/forums/topic/359111-rb30-failure/
pull the girdle off and lay the main bearings out in order and see what they look like.
ps. all the plugs are still in the crank? especialy adjacent to the damaged bearing..
Will be doing that tomorrow and checking everyones still where it should be
i just cant believe how much colour difference there is in the rods
Edited by 32rrr
https://www.sau.com.au/forums/topic/359111-rb30-failure/#findComment-5735896
I built this engine. About 2.5 years ago.
N1 pump was used at customer's request. I suggested using a Tomei as we were building two other Tomei pump engines at the time and you can't really go past them for quality/reliability
The N1 pump was brand new. Collar was new and fitted by an engineer. We always check clearance on collars when we fit them.
It had a ROSS balancer too so not a harmonic issue I don't think.
Such a shame, that engine was destined to make some bigger numbers.
Although I can't prove any problem with the N1 pumps, we just stay clear of them now due to the pump failures we have seen.
https://www.sau.com.au/forums/topic/359111-rb30-failure/#findComment-5738378
What was the rev limit on this engine and was the limiter regularly hammered? I am interested (worried) because an N1 pump has gone into my RB30 (yet to run). One reputable RB30 builder here won't touch N1 pumps because of a number of failures but others say that they are ok with a rev limit such as i am planning to use: 6,800rpm. Or is the "safe" limit lower on an RB30?? Engine above does not appear to have been highly stressed - planning to run 18 - 20 psi with a GT3540 and looking for around 300awkw.
https://www.sau.com.au/forums/topic/359111-rb30-failure/#findComment-5738918
Reved to 7, limiter set at 7250, hardly hit the limiter.
To anyone with a N1 pump on any engine.. i seriously suggest changing it as the pressure gear just isnt thick enough in the area's where it needs to be.. i will use a stock rb30E pump before i use an N1 pump again
Car was run in on the dyno, was going strong untill she went bang, the oil pump is quite spectacular
Crank and 2 of the rods are throw aways, pistons will be reused just have to decide what to do, but for now a bog stock rb30e bottomend has gone in just to get the car mobil again.
when i can see the funnier side to it.. i'll throw up pics around the place, i really have to give it to the spool rods considering the heat damage that they have copped i honestly dont know how they didnt bend and leave the block
https://www.sau.com.au/forums/topic/359111-rb30-failure/#findComment-5739959
I purchased a second hand N1 pump from someone on this forum (he took it out of his car because he was paranoid) and been using it ever since, the pump is 4 years old now and ive been using it in my RB30 for 3 years, its been to 2 different countries and traveled a LOAD of km's with revs up to around 7300 with stock balancer when racing. It has withstanded temps of -10deg where you HAVE to use anti freeze and also hot weather also.
I use a very soft rev limiter with the vipec and stock balancer but i ALLWAYS use the best oil... Motul.
Only different thing i did before installing it was lock tight the screws on the back.
N1 all the way IMO even after 100,000 km (road) its still going strong! just ran a 10 last month.
The N1 pump has served me great.
https://www.sau.com.au/forums/topic/359111-rb30-failure/#findComment-5740613
Correct me if i am wrong but I THINK that when the gears gave way and siezed the engine must have had some torque behind it and kept spinning inside the pump and just shredded them away...
You can see there was a f load of heat inside there at one point :)
nice main bolts btw
Where the hell did the two flats go?
https://www.sau.com.au/forums/topic/359111-rb30-failure/#findComment-5740649
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
