In my previous gtr, i built the engine back in 2005 & used an n1 pump as back then they weren’t breaking & there was no stigma attached...to date, that engine & oil pump is still going strong & makes 400awkw.
My mate also runs an n1 oil pump in his r33 which makes close to 350awkw & he has covered about 50,000km over the past 4 years, no problem whatsoever!
On the other hand though, when i built my most recent engine in 2009 I also used an n1 oil pump (making 405awkw) & the thing broke after a few thousand kms – yes i was revving hard when it let go & hit the limiter, had a ross balancer.
From what ive heard & also seen with my own eyes, the old n1 pumps are solid whereas the most recent n1 pumps are crap – there was speculation that the manufacturing plant had possibly moved to china? Not really sure myself...
Correct me if i am wrong but I THINK that when the gears gave way and siezed the engine must have had some torque behind it and kept spinning inside the pump and just shredded them away...
You can see there was a f load of heat inside there at one point :)
nice main bolts btw
that was my old N1 pump, i was sooo paranoid about it after TM ruined 3 new engines in his R33 after he broke 3 N1 oil pumps... He was revving too 9500RPM but when they all broke,
Anthony that N1 pump was running in my engine without a crank collar too.
I ended up going all out buying a Tomei pump and collar etc.
pull the girdle off and lay the main bearings out in order and see what they look like.
ps. all the plugs are still in the crank? especialy adjacent to the damaged bearing..
Can you please do this and post up the pics of the bearings, both front and back of the bearings. :thanks:
Yeah :) was not going to mention any names.. but il never forget that day.
My rb30 had a oil leak and i could never pin point it. i worked out the front seal was leaking. So pulled the engine down and replaced the seal but it was a little crooked but it took sooo long to get that seal in there it was a bastard i tell you, my mate was helping me and he kept saying just leave it like that it will seal fine but me being a perfectionist in the most anal of times i decided to remove it and try again because i did not want to go through that all again. When i removed it i heard a litting "ting" on the concrete in the garage and found a piece of my stock oil pump WTF!! the oil pump was cracked but still working and it damaged the seal! thats when i called you and hassled the shit out of you to organise someone to pass on the oil pump to me... thanks for that again it saved the day :) that rb25 oil pump had alot of limiter bashing and was about 250,000 km's old as it was the original pump on my car.
I never rev my rb30 over 7300rpm and ive used a very soft limiter ever since. Seems to be working fine in these conditions.
nice main bolts btw
More of a rhetorical question lol.
As for the N1 pumps old and new. I started noticing most failures about 2.5 years ago. Prior to that we could never fault them.
There was another RB30 I built around the same time for a guy after he blew the headgasket, due to tuner stupidity, detonated the shit out of his old engine and blew the head gasket through...38 deg timing at 6500rpm and 24psi boost seems to have that effect :dry:
Anyway, we pulled the pistons out for good measure to check them for damage and the rings were seized. So I convinced the guy to check his brand new N1 pump (1000km old)....had a crack through the inner gear. Engine never saw over 6800rpm
From then on I never used another N1 pump unless the customer absolutely refuses to buy anything else.
1000km at no higher than 6800rpm, collar fitted and ROSS balancer - gotta be something they are doing with cheap manufacture to have SO many fail so close and all around the same time.
Prior to that we only ever heard good things about the N1 pumps but were just starting to hear of a couple of failures here and there, never thought too much about it until 3 let go under non-extreme conditions. I'd say why take the gamble? If you have an N1 pump and it's old than 3 years, chances are it's gonna be fine. If you have bought one recently, I'd definitely stay away from it. Not worth the risk IMO
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
