Just wondering how to replace the parker lights on an R33 Series 2 do you have to take the whole headlight of or is there some other way to get to it??
There is a little rubber flap kinda thing you have to jam your fingers through. Its hell tight. Makes it easier if you remove the fuse boxes etc that are in their way. But no, you dont need to remove the headlights.
They are a twist fit. from memory about a 1/3 turn anti-clockwise and they will unclip. They can be tight, so if you manage to make room, use some pliers. lol.
aha thanx heapz man well i guess ill give it a go and probz be back with cut fingers aha thanx again man
No problem. yeah its a hell of a tight fit. So if i was you save yourself the swearing and move as much stuff as possible.
Now i think of it, the hole you have to go through to get to them, is a circle, and the rubber/plastic cover is circle too with an "X" cut into it. All from memory mind you. Mine have lasted 3 years since last changing them.. Touch Wood.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
