Hey guys,
Need to move my car from wreckers back home (recovered stolen)
It's apparently got no wheels and no seats.
So im looking for some:
R34 GTT stock wheels with tyres (or something similar 5 stud cheap - r33/s15/s14 stock)
And R34 GTT front seats (also need rear seats but not as important yet.)
email/pm/call/sms if you can help out
Mob: 0422 850 698
email: stephen.hendicott @ gmail. com
Cheers
Steve
https://www.sau.com.au/forums/topic/359118-r34-gtt-stock-wheelsseats/
I'm a little far away but i have 4 x 17 inch rims (8's and 9's) with new tyres for $400
If i were closer i'd try meet half way to help out but i am in NSW so i think that plan fails =/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
