Bull Sh!t Roadworthy Rules
slinky-minky
 Share
  • Replies 62
do you actually think before you post threads?
Hamish - Yeah I do. It was posted as a conversation point to get people posting and interacting. Do you think before you reply???
- Chantalle
You need to be able to clean your windscreen - if you go for a roadworthy check or to clear defect, they will check this:
As I mentioned above I don't think it's a bull shit rule, I think it's bull shit that something that can be fixed immediatly be used to defect a car based on the sole discretion of the issuing officer. You'd be pissed if you had to take time off work/whatever keeps you busy, then have to shell out $88 to have a whole new RWC certificate writen, stand in the massive line at VicRoads, all because the water bottle wasn't full.
They should introduce a points system with each dfectable item have a points value rather than just needing 3 things.
Matching front tyres-
When I asked the guy at the tyre service to explain (as I had never heard of this) He explained that it wasn't due to the effectivness and consistency of breaking, like one would assume It's actually due to safety in the event of a blow out and steering capacity.
Having hit my washers once due to a bunch of crap on the window..and having a empty bottle.
All I did was smear the windscreen and lost all visablity, I had to pull over and clean it then filled up at first chance.
I can see why it would be a RWC issue.
that said every cop I have met would not dick some-one for that UNLESS they were being a cock and deserved it..
The fact that you don't have to carry a spare tyre.
But if you do it has to be in roadworthy condition...
This one seems ridiculous at first, but I can see the reasoning for it. Being stuck on the side of the road with a blown out tyre and inability to drive isn't dangerous, but driving with one shagged out tyre is - they'd rather you do the former.
Whilst there are a lot of seemingly bullshit items to get called up on, keep in mind that they were decided at one point for a reason. What I do agree with, is that some should not require an inspection or roadworthy certificate to pass on if you can fix it in the time the officer is there with you. A demerit points system for the vehicle's registration would be better than having to take a day out of work to mess around with clearing a defect. Also, that 90% of the cars on the road would have some roadworthy issue to get called up on if you scrutinised them hard enough...say, in the way that imports get scrutinised. Most people wouldn't believe or have even heard of these roadworthy issues, but reading this thread won't surprise most import owners.
That handbrake click rule is BULLSHIT, technically its legal if it HOLDS the car in place. All it means if your handbrake clicks too much it just needs the cable to be tightened.
Mind you i had my car for 3 years and use the handbrake on "skidpans ;)) and its still tight as f**k, only manage like 5-6 clicks?
Whats with the hand brake rule? I mean as long as it works right? I mean so what if it has one extra click, run for the hills my car is unsafe.
Some of the roadworthy rules are bs, like not being aloud to have metal on your steering wheel. Well my gts2 had a factory fitted momo with a metal centre, try explaining that to a cop or for a rwc.
Same with windscreens, you could replace your windscreen due to minor chips and then drive down the road and cop a stone and your unroadworthy again.
Thing is most cars out there are ''unroadworthy'', I'm sure if they pulled over granny in her ford laser they would find blocked washer jets, rooted 10 year old tyres and no washer fluid.
 Share
    • Any chance the zero demand ignition table is messed up? Or possibly the minimum tps for it to engage zero demand?
    • 32010-AA520 - R34 RB25DET manual transmission, you can buy this new. You'll need a pull to push type clutch converter (to use R33 clutch kits), or buy pull-type clutch (R34 clutch).   R33 part number if you're lazy: 32010-21U00     Applies: RB25DET.MT.F5; Notes: FS5R30A
    • Hi All, Ive recently pulled my head in and gotten started on my 2year long project for my R32 RB25 swap, I went into it head high and confident it was an easy swap and plug and play wiring. I was wrong. The engine is a S1 RB25 and I'm running RB25 ECU And loom. I got the swap done a few weeks ago and have been working on the car on my time off, however i cannot get the engine to run, at first the engine would crank however the fuel pump would not run,  i dove a little deeper and realised that i would need to connect the wires from the RB25 Body Loom and the RB20 Body loom. went through the ECU pinout and followed the wires from the Body looms one by one to find what was needed to start the car. Now I have rewired the RB25 loom with the old R32 Body loom attached, however i am still having issues starting the car, now the pump works but still wont fire.  The car has spark but looks very weak, however I'm suspect that its not getting any fuel. I have read a few posts related to the "Main plug" near the air intake however cannot find any information on what wiring to hook up to where.  If anyone has done this swap, or has any knowledge at all on RB25's into 32 i would really appreciate your comment regarding this, im really keen to get this car finished.  Thanks in advance
