Hi guys,
Im looking for a few parts:
* L/H Turret mould (door apature mould)
* Demister vents in the dash (centre ones)
* R/H Inner weather strip (the one on the door trim)
* L/H Reverse light
Let me know what you want for them and postage to wingham nsw 2429
cheers
Edited by way02b
https://www.sau.com.au/forums/topic/359239-r32-parts/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
