http://smh.drive.com.au/roads-and-traffic/stoner-brings-back-room-for-error-on-speeding-20110330-1cgdb.html
There is hope!
IN ONE of his first acts as Deputy Premier, Andrew Stoner has not only ordered the Roads and Traffic Authority to reinstate the leeway given to speeding motorists, but he has asked for it to be increased.
https://www.sau.com.au/forums/topic/359291-bang-continued/
It is good news, but might be also a publicity stunt to get some easy popularity... Which they've certainly got lol.
Still, it'd be more impressive if they actually took safety to the motorist rather than just allowing the "only speeding kills" culture to continue.
https://www.sau.com.au/forums/topic/359291-bang-continued/#findComment-5738873
Much as I'd love an Aussie autobahn, can you imagine if we actually had one here in Sydney?
You'd be hammering down the fast lane at a 160km/h cruise and all of a sudden there'd be a beige camry merging into your lane doing about 40 with no indicator.
https://www.sau.com.au/forums/topic/359291-bang-continued/#findComment-5739198
I think this was all a sham. Set a rumor in place to be hated, then turn it around and add a little sugar on top for quick popularity without even lifting a finger.
Completely OT but i think i've seen you cruising through c'town a few times, particularly blaxland road / gilchrist drive etc. Nice looking GTR too!
https://www.sau.com.au/forums/topic/359291-bang-continued/#findComment-5739275
    • Goddam! Thats the dream, neo heads seem hard to come by these days though, best I've seen is $2-3k or there's a full motor for $7k atm
    • Cheers for the input, 450kw on poncams is impressive! I assumed you'd need 264 or 272 for that power level, good to know you don't need to rev that high to hit it, just don't want to buy the cams etc then find out the hydraulic lifters suck haha The box will be getting reconditioned too, possibly an aftermarket gearset if it turns out they're toast, cheers I'll keep that in mind
    • I think definitely get a manual oil pressure gauge on it then. Double check if it's really dropping pressure that low.
    • yes sorry i should of spoke better, all sensors are grounded into their specific homes in the ecu, the ecu is then grounded to the chassis itself along with the EFI relay.
    • I'll check the wiring plan tomorrow. Now when you say ALL the earth's are to the chassis, is that including the sensor ground from the ECU? Certain items should not be grounded to the car/body/chassis, they should ground back to specific ground pins on the ECU.
