FST32 is for sale!!!
Hi-flow turbo, 3 inch exhaust system, high flow cat, 600x300x76 Bar & plate FMIC, turbosmart boost controller, turbo XS plumback BOV, JR pod filter, Microtec LTX12 computer (yet to be fitted), strengthened gear box, front strut brace, SX adjustable fuel regulater, Walbro 400hp intank fuel pump, High pressure organic clutch (good for up to 550hp, new from nicks clutchs), machined flywheel, APEXi boost gauge, Nismo 400r front bar, type M sideskirts, platinum tip plugs, brand new clutch master cylinder,
Pioneer 4 x 50w MP3 Head unit with remote, VDO Dayton 250w front splits & Kenwood 4 way 400w 6 x 9 rear speakers.
Power steering, air-con, 4WS, 5-speed manual, & all other standard R32 options.
Rego till June 2004
$20,000 negotiable. PH: 0412191969 anytime.
https://www.sau.com.au/forums/topic/35937-r32-gts-for-sale/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
