  • Replies 77
I remember Peaks.. They were really good guys. Echow (spelling?), did me a killer deal on some wheels..
I went on an EVO GSR cruise with John in his evo and we were told we would get fined $2.00 for passing the lead car aslo they were doing 60 kays on the freeway to Murray Bridge!.. from memory we ditched that cruise and met up with some skylines that night.
Im not insulting.. just saying what happened...
As they say, "what ever floats your boat"....
Haha I know the cruise you mean it was a night cruise way back in the beginning and the organiser then thought that would be funny
"I went on an EVO GSR cruise with John in his evo and we were told we would get fined $2.00 for passing the lead car aslo they were doing 60 kays on the freeway to Murray Bridge!.. from memory we ditched that cruise and met up with some skylines that night. "
a note to you though they are no longer in the club!!!!! The left a few weeks after that cruise, but I dont blame you, it was pretty lame, things have changed since then, trust me - I am now in the club :-) Nah seriously it is all about fun now not Nazi'ism come check it out
Guest Miss_Nismo
hahahahahaha omg
new addition to the event
#3
In conjunction with the Show 'n' Shine
MGEC PSi GT Autosound presents
SPL Battle Glenelg
Sunday March 28th 2004
Wigley Reserve Glenelg
GT Autosound displaying their 180sx built for DB
"If you can beat it - there is a prize waiting for you"
ENTRY FREE
see: http://www.gsr-evo-club.net/forum/viewforum.php?f=45
or contact Sam - [email protected]
0413 495 284
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
