hello guys. any reason why an rb25det,would run 20 degrees, carnt seem to get 15 no matter what i do, unplug TB./ tryed adjusting cas. tryed turning down aac valve, somone told me autos run 20. but i put manual in it.an tryed two different ecu's but still runs on 20degrees, according to data scans. any help would be great. carnt boost over 8-9psi with out cutting out.
https://www.sau.com.au/forums/topic/359461-running-20-degrees-timming/
tangles- i will check,but dont think so.-
adriano- just on basic conzult or datascan.nistune, not running nistune ecu yet but. tryed on sr20 and runs 15.
DVS32R- cuts like maf limits, so basicly cuts everything, soon as i go over 8-9psi. back off a fraction and comes to life again. just a fast cut out, was thinking timing was too high makeing things max. but doesnt do it under 8psi.
now im finding car can stop randomly and start straight back up- if i shake maf somtimes(not roughly) car will just stop.. and i have to restart it... could if be faulty maf. i grounded maf to chassis few weeks back and didnt do it again, stoping random that is. not the cut on boost.
turbo is ar 60-1.00, 3'' straight threw exchaust exchaust temp sensor not in cat,its just clamped to cat,was like that when got it.but dont think thats the cause.
greeedy intake plenuim stock TB
steel headgasket
big IC
pod
fpr
38mm external
i havent check to see what fuel pumps in it ethier,will very vry soon
Edited by nisn
i had an issue like this once !
built an rb26 .... for some reason the CAS sensor LOOKED like it was set to retarded ( far left ) but timing light was telling me 20degrees ... timing was obviously retarded ( CAS ussually sits in the middle for 20degrees... plus the engine revved retarded ... checked Timing belt again ... perfect !
timing light says 20degrees ..... got it dyno'd and timed instead at chasers. still no sure what happened to that car chasers motorsport didnt know either ( they checked TB and timing light also )
apprently the bracket the holds the CAS sensor in (behind timing case) fractures in rare cases. besides that :S id like to know whats going on !
still didnt get to the bottom of it , neither did chasers ( didnt spend to much time on it )
timing kept saying 20 ( obviously not 20 ) just played with the CAS on the dyno until we where happy :) lol funny engine
timing light loop that nissan recommends using can cause timing lights to read wrong, i had this happen the other week on a GTR, i didnt feel it was correct so i put a spark lead from the #1 coil pack to the #1 spark plug to check timing and it was 10 degrees different to the timing loop.
always best to use the spark plug trick
+1
think it may be white wire near ignitor actually ....
That white wire on the two pin plug near igniter is coil pack positive power.
The Black/Pink wire on that two pin plug is Cylinder 1 fire signal wire (On R33 GTS-t S1)
+2 do this before anything else
ok will do that in the morning cheers, the timeing on conzult/datascan. That is reading ignition timeing right? thats what is at 20. should that be right.
in conzult,i can change timeing- the basic check.
such as check timeing cylinders,so on' i change timeing to -15.click and bam drops idle and accually sounds like where motor should run. but obusly i carnt burn to ecu. it doesnt stay at 15 when turn laptop off.
but in saying that,when i change it too -15. it reads 10 degrees on datascan??
no more when i do another timeing light read tomoz....cheers
Edited by nisn
The way it
Works is the consult timing shoukd say 15 ( or whatever te base timing is for ur engine) then u need to set the crank angle sensor timing to match the consult, u do this by using a timing light as i described above
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
