  • Replies 96
damn nice shot zennon! i prefer digital myself, im too lazy for analogue :P
my new ride.
background was a bit meh and i got a pinch flat on the way to taking this. jumping gutters on a fixie is something ive got to learn, lol. heaps fun bike to ride tho once you get used to a new riding technique.
sorry for double post, cant edit after a certain time it seems, lol.
couple more shots of the bike.
framing was good, positioning of the bike not so good, lol. was in a rush and didnt take notice of the damn drains behind the bars/front wheel
do want!
I've heard all the cool kids are using 1920x1200 :P
Exif? (esp camera & lens)
Stitched Panorama, apparently exif didn't make the transfer :P
Camera: Canon EOS 500D
Lens: Canon 10-22 Wide Angle (love that lens!)
F-stop: F/10
Exposure: 1/250
Iso: ISO-100
Focal: 10mm
No flash
Just got back from visitting my parents down south over the long weekend.
Grabbed these from Gracetown:
My dog is a mountain goat! She sleft for hours after this :P
And this is my parents backyard:
Cant wait to finish my apprenticeship so I can move down there! So over the city.
Jay, how do you stop?! :P
cant stop, wont stop! wooo :P
nah you kind press back on the pedals. helps when the pedals have toe straps on them, and a front brake helps even more. for now i just ride it slowly so i have plenty of space to slow down in, lol
Edited by Jay019
Thanks - was a bit of work.
Here is one from the weekend. Car belongs to Steve - the new owner of City View 4WD park outside Beaudesert.
Winch Truck by ZENN0N, on Flickr
Edited by ZENNON
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
