I need to change my timing belt, and about to buy a kit, but i want to make sure it is the correct one for my car. apparently there are 3 different belts??
my car is a 1999 WGNC34 Series 2 (RB25DET Neo) does anyone know how many teeth are on the belt? 141 teeth or 133 teeth?
Dayco Timing Belt Kit - PART No: KTBA173
Cheers,
Chris.
https://www.sau.com.au/forums/topic/359479-c34-timing-belt/
i just ordered this today
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=120704897237&ssPageName=STRK:MEWNX:IT#ht_1749wt_856
CHARGED said he ordered the same kit and it fitted up fine, the belt and pulleys are the same for all rb25's its the waterpump that varies and i think this waterpump is the slotted type (fits all models)
https://www.sau.com.au/forums/topic/359479-c34-timing-belt/#findComment-5741623
Just had the world's worst with the 25G.
Recommend you put in a full kit with both pulleys. Also replace water pump, get one for a VL commonhore. Also replace all the ancillary belts. It may cost a bit but can save you heaps.
https://www.sau.com.au/forums/topic/359479-c34-timing-belt/#findComment-5741677
thanks for the advice guys... the one you got Tom, sounds like the goods. Yeah i thought all the rb25 kits would be ok, just started second guessing it when i read the description of the one i was looking at
http://cgi.ebay.com.au/TIMING-BELT-KIT-NISSAN-LAUREL-SKYLINE-STAGEA-/140461661396?pt=AU_Car_Parts_Accessories&hash=item20b42adcd4
didn't even think about getting one from the US...and genuine too! it would be worth getting the kit with the water pump. i will send the guy a message and see if he has any more :)
https://www.sau.com.au/forums/topic/359479-c34-timing-belt/#findComment-5741774
For what it's worth I used the dayco kit that comes with both pulleys and its been all good for 20,000 so far, definitely do the idler and tensioner at least, water pump should be good for 200,000 but it's up to you for your piece of mind I didn't.
https://www.sau.com.au/forums/topic/359479-c34-timing-belt/#findComment-5741856
yeah, don't really need the water pump, but worth getting if only an extra $50 or so.....
I noticed in the dayco kit photo there is something sitting under one of the pulleys? not shown in the US ebay photo.... is it important ?
https://www.sau.com.au/forums/topic/359479-c34-timing-belt/#findComment-5744629
yeah not the black rubber rings... the thing one of the pulleys is sitting on... i think this could just be a generic stock photo.
Well i ended up ordering the kit from the US with the water pump. Not that i thought anything was wrong with the dayco kit. I just thought and extra $50 for a water pump and thermostat was a good deal, and with the car being 11 years old, it does not hurt to change them anyway :)
https://www.sau.com.au/forums/topic/359479-c34-timing-belt/#findComment-5746043
Good choice to get the water pump. Afterfitting the belt kit someone (not me) overtensioned the W/P fan belt which overloaded the bearing, which shagged itself and the shaft snapped. The fan uniy went for a free flight under the bonnet and went thru the radiator. All very expensive.
https://www.sau.com.au/forums/topic/359479-c34-timing-belt/#findComment-5746174
The "thing" in the photo you are reffering to, is the spring loaded tensioner unit that one of the pulleys is attached to the engine by. The other kit does have it, but it is shown inside the pulley, not seperate from it.
If it isnt supplied its no real issue any way as the spring unit is pretty indestructable, its the bearing that usually fails
(isnt it hugh? :laugh: )
https://www.sau.com.au/forums/topic/359479-c34-timing-belt/#findComment-5748221
quick update...
got my package from the US... prtty happy with it :) awesome value and all items were sealed in genuine packaging.
Fitting everything this weekend
Should i try and source any gaskets? or do I just use some sort of gasket goop?
https://www.sau.com.au/forums/topic/359479-c34-timing-belt/#findComment-5766842
FYI Guys,
I can get timing belt kits and water pumps for those interested.
All tensioners are NTN, seals are NOK and belts are gates (Japanease/American quality)
Our listings show that all the RB belts are the same, the tensioners vary from the 26 though.
Water pump is the same deal, can share from 20 to 25.
:thumbsup:
https://www.sau.com.au/forums/topic/359479-c34-timing-belt/#findComment-5772906
Well yes and no I did the RS at 110k and there was no info like this around. We are talking 2006 Just did the belts. Have had no probs so far. Touch wood The 25g had the belt only replaced at 106k. The idler pulley failed at 153k. The water pump shaft broke the next day caus someone overtightened the fan belt.
Incidently as I said earlier, the VL water pump is the same as but is less expensive.
https://www.sau.com.au/forums/topic/359479-c34-timing-belt/#findComment-5773146
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
