Hey guys as mentioned in the description.
I'm after a these parts in good working order:
Stock Fuel Rail
Stock Fuel Regulator
RB26 coilpack cover.
Im located in Richmond, NSW (Western Suburbs Sydney)
would prefer local pickup if possible.
Cheers
Sloane
https://www.sau.com.au/forums/topic/359486-wtb-r32-gtr-parts/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
