i believe the rears are going to stick out past the guards by around 10-15mm
use the following link to see what youve got ( unfortunately it doesnt do half inch graduations , you have to guess that bit )
http://www.jonathanrowny.com/page/offset-calculator
Edited by Trick V35
you can try a camber kit but it will ruin tire life in a hurry.
you could get your guards modified but it could look ugly.
or you could find someone with a coupe that wants to buy them off ya.
try them on for size first.... you may just like the look of rim poke.
  On 01/04/2011 at 11:18 AM, yunghumma said:
guess I'll soon be seling some nice rimz
I know the sedan has a little less room than the coupe, but I still don't think that size & offset you've got will be too big or aggressive at all mate... There are guys running 10.5" in +0 or less offset with just some tweaking of suspension, light guard roll & right tyre size so you have HEAPS more room compared to them...
Sorry, my bad.... just done all the measurements on my own car and yes the offset should be just right.
Rear rim poke will be about 7mm with standard suspension..... but if you lower the car, it will tuck under.
I'd fit a 245/35/19 tyre to the rears...
  On 12/04/2011 at 5:51 AM, Cobey said:
should fit no drama!
if not ill buy em for track rims. :P
20x12 -3 will be going on my coupe rear soon....
JUST REALISE I MADE A MISTAKE ON THE FRONT OFFSET IS 20 NOT 25
AND YES IM NOT KEEPING THEM AS SOON AS I SELL THEM IM GETTING SOME WHEELS WITH PROPER OFFSET
AS I FOUND ON G35 SITE
1st GEN G35 Sedan OEM Wheel Specs
Sport Model (2003-2004) & Non Sport Model
Front & Rear: 17x7 +45mm offset
Weight: 23.2lbs
Sport Model (2005-2006)
Front & Rear: 18x7.5 +45mm offset
Non Sport Model (2005-2006)
Front & Rear : 17x7 +45mm offset
Commonly used after-market offsets:
All first Gen years
Front width: 8.5" +29-30mm offset
Rear width: 9.5" +35-40mm offset
Rear width: 10" +42-45mm offset
245 series front tire and 265-275 rear tire are most commonly used
  • 10 months later...
Sorry to bring up an OLD post but I am looking at Factory (19x9 +47 F and 19x10 +30 R) 370Z 19" wheels
Any clue these will fit because I reckon they will look sweet on a V -Series sedan?
Nope. Do reckon they'll hit your suspension.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
