hey guys dont know if im in the right place here but i got a 4 door 32 wid a 33 rb26tt in it and when driving it the smell of fuel is pretty intense i replaced the fuel pump seal but no luck iv cheked my injectors and one of them seams to b leaking a little bit not shore if that would b enough to cause the hectic fuel smell inside....wat do use rekon should i replace that injector? any advice apreciated chers
julzy :)
https://www.sau.com.au/forums/topic/359515-fuel-leak/
it will be your injector collars...
or "O" rings...
a lot of "well known mechanics" use these O rings because the old ones corrode from old age.
but if you dont use nissan they dont seal up correctly and they make you question why you're getting 3km/litre economy.
ps: drop the midland lingo - not many people understand it :P
https://www.sau.com.au/forums/topic/359515-fuel-leak/#findComment-5742520
yeah i just had a 3 inch exhaust put on from jpc and as far as i no they put all new flange gaskets in.... and the leaky injector is the one closest to the fire wall so im thinking thats gota be the problem...
soo you think its an o ring for the injectors? im thinking of getting bigger injectors anyway so my best bett would probably replace the lot of them :) ill put some pics up tonight it doesnt look to crash hot its just about too get a kit n a new paintjob next week :)
ps. this isnt midland lingo if it was id be using words like dats dardy and my unna car or can any cuzins help me out der? haha :P
chears guys
https://www.sau.com.au/forums/topic/359515-fuel-leak/#findComment-5743221
  • 1 year later...
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
