Item: 1994 Gts R33 non turbo s1, 5 speed manual. 127,000 Km's
Item Condition: One of the cleanest 33's around.
Price: $13500 ono with 12 mnths rego.
Extra info:
Rb25de , 5 speed manual
BC racing coilovers
Front and rear strut bracing
17x8.5, 17x9 advan wheels. Also will come with 2 17x7 wheels.
Boss kit, d1 spec detachable boss
Deep dish steering wheel.
High flow cat with 3inch stainless exhaust. Real loud sounds tough.
Aliminium radiator
Exedy Heavy Duty clutch, 15,000kms old.
Aftermarket rear bar with nismo sideskirts.
Timming belt and waterpump had been changed at 100,00kms.
does not leak any oil.
Car has always been serviced with the best quality oils every 5,000kms
Pioneer headunit wit 4 channel amp with a 10inch kicker sub.
It has been drifted on the track a few times and has never gave me a problem and goes great for a NA.
Car is in great condition inside and out and has had a full respray less than 1 year ago.
Na RB25's are pretty much unbreakable and it never misses a beat.
Excellent car for a p plater looking to get into drifting.
Pictures: Will be up soon.
Contact Details: cam, call or msg me on 0416410083.
Edited by cameron666
Extra info:
BC racing coilovers
Aliminium radiator
Car is also ENGINEERED for:
Exhaust
Coilovers
Strut bracing
Steering wheel
Rims + spacers
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
