So I discovered a few weeks ago that my rear passenger seat floor was drenched. Like Soggy, soaked drenched.
U used up a whole roll of kitchen towel drying it out. It was nice and dry AFAIK for the past few days.
Today after installing all the stuff at Scott's place I noticed that area was wet again.
Does anyone have any idea what I should be looking for? I thought it would've been a doorseal/windows leak but that seems unlikely as the seats are dry. Its just the carpets thats drenched.
Really want to fix this up as I dont want the carpet rotting and having to deal with the stink of damp carpet either!
https://www.sau.com.au/forums/topic/359594-m35-water-leak/
  • Replies 60
Posted Images
Where does the plastic tube for the rear window washer run? Could it be that?
https://www.sau.com.au/forums/topic/359594-m35-water-leak/#findComment-5742890
The air con tube pokes through the fire wall on the passenger side maybe the rubber has split. Do you only get water after its rained or after the aircon has been on?
There is also a big rubber grommet just under the windscreen on passenger side for the ecu loom. That could be possible and next time it rains check it then so you can see where it starts from.
https://www.sau.com.au/forums/topic/359594-m35-water-leak/#findComment-5742992
Well the water is leaking into the REAR passenger (left) side floor...so not sure about all that.
I think the water only appeared after its rained...certainly not aircon.
https://www.sau.com.au/forums/topic/359594-m35-water-leak/#findComment-5743028
the rear window washer pipe runs down the drivers side
got sunroofs? check the rain pipes. i THINK the front one goes forward, and the rear one goes to the back.
check door seals, window seals. make sure the windows are all the way up.
https://www.sau.com.au/forums/topic/359594-m35-water-leak/#findComment-5743084
if its built like any of the nissans i've had (s13, r31, r32, c34) the washer line runs down the passenger side of the car under the carpet
i reckon that would be your best bet
I agree with Iain on this one. I've seen the plastic tube for the rear washer on the driver's side in the M35, under the door sill trim. So not the culprit in this case I would think.
https://www.sau.com.au/forums/topic/359594-m35-water-leak/#findComment-5743429
ive stripped two M35s. i KNOW where it is lol
i was basing my suggestion on this.. thought iaiaiaiaain was arguing saying he knows (otherwise)best lol
Didnt Iain and Leon both said the rear washer pipe is under the driver's side?
i still reckon theyre maybe a hole in your floor.. all it needs is a crack.. once its moist it will hold water and attract more...
the only other thing you can do is start pulling it apart to find a source...
https://www.sau.com.au/forums/topic/359594-m35-water-leak/#findComment-5744469
Great...and if there is, does it make my car unroadworthy?
Can't exactly just seal it right? LOL
https://www.sau.com.au/forums/topic/359594-m35-water-leak/#findComment-5744491
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
