I was thinking of getting a set of these, wanted to know if anyone has got these on there 34's
http://www.migicute....nskylr3498.html
I checked on there site and they do not ship internationally but I was thinking of posting it to my cousin in the states and them get him to ship it to me or to use http://www.parceliton.com.au/ I have use them before to get things in.
The ones I want are The East Bear ones but I am looking at $550 Plus shipping (greenline.jp) so prob be over $600 landed so this might be a better option.
Also I looked at http://www.rhdjapan....ne-2-door-51538 they are on sale atm but they do wholesale prices would it be worth doing a group buy not sure how many we would need to buy though and weather the discount would be worth it.
https://www.sau.com.au/forums/topic/359616-r34-led-tail-lights/
  • Replies 73
I've never seen the taillights from migicute, they look weird lol
But I've got a set of LED taillights on mine, they are the EastBear copies, everyone has them lol. Which I reckon looks 95% the same. And they cost $150 lol
I'd be interested to know a price shipped.. I'd be interested.. I have the Eastbear ones like Charles.. But the plastic on these look more stock than the East Bear ones.. If you go ahead let me know what price they are
Wow love those sunline LEDs.. I gotta get some of them! Any recommendations on where to buy them at best price?
they are custom from sunline racing on an exchange basis
we can liaise with them
turn signal "led" is an option
but they are nice to drive with - even better if you have the LED reverse & fog set ;-)
Charles I looked into these, they look the best, but from mem they are around about the $1000 mark lol
I did find this on Jap Yahoo...
http://page10.auctio...ction/m81153214
These look so close..
translated with babelfish into engrish
Engrish Version
  • 1 month later...
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
