As title says, how high can a stock RB25DE rev up to effectively? Being an RB motor i'm expecting the normal 7000RPM to be a 'safe' redline for the internals. Would there even be any point in increasing the redline as the internal components for example camshafts, valves, crank shafts, etc might not support any higher than 7000RPM, and drop the power afterwards instead of increase? As horsepower = (RPM x torque) / 5252, I'm weighing up the benefits of removing the rev/speed limiter.
Many thanks.
https://www.sau.com.au/forums/topic/359667-how-high-can-a-stock-r33-rb25de-rev/
they run out of power after about 6 anyway. unless you had different profile cams and stuff it wouldnt be worth it. my 25DET revs out to 8 but only makes power till 7 really (on its current tune)
What you need is two of the big ones, and you need them by tonight.
No, seriously, if you have an NA the best way to make it quicker without wasting huge sums of non recoverable money (is it ever ?) is hiding a nitrous set up.
No point. DE, lol!
That's probably one of the worse replied to this thread lol. Why do NA racecars or any racecar for that matter want to rev higher then?
Yeah seems like no point as power drops before redline anyways. In saying that it would sound awesome with an extra 1k RPM lol.
Edited by TyresBro
In short, with different cams you can make your big power higher in the rev range (at the sacrifice of lower rpm power).
So racecars with a big redline obviously aren't using the same cams as an average street setup. You are right though, in theory power = torque *rpm, but in reality the engine is incredibly inefficient, and the cams are designed to give a power band at certain revs. The stock cams are not designed to cope with 12k rpm, they just couldn't get the fuel and air in.
they are setup to run like that. Formula 1 cars are designed to rev high and get there quick, why? Because they are the pointy end of motor racing , Your NA skyline.... Is not the same as this
FYI, before the limitations on engine development in F1, they would spend billions doing this...... Hence why they rev hard and make such good power/torque despite being NA V10 3L then V8 2.4L
(Bring back the 1200hp turbo days :), would be amazing)
2013 they'll be bringing back the turbo days, but similar hp and 4 cylinders instead (unless various parties manage to change that now-plotted course for f1).
Those old f1 cars used to push out 1500hp for qualifying laps, which is as long as the engine would last lol
Yeah it was a rhetorical question to Kinks. My understanding of upgraded cams is that they definitely do push the powerband higher in the rev range (assuming your engine can support it), but because it's higher RPM it = higher power.
Now it would be stupid to compare our engines with that of competition race cars especially F1 (especially a DE). These engines are tuned to be on the edge of it's limits. The point was if we could squeeze an extra few kW out of a higher RPM as it feels as though there are about 500RPM - 1000RPMs of extra power left with intake and exhaust mods.
I think summary = dyno time.
Your power will fall off before 7000RPM regardless of bolt on mods on a NA RB25.
If you want a decent increase in power on a RB25DE run nitrous, other wise I wouldn't even bother modding one past an exhaust/intake. Absolute waste of money for the tiny power increases.
I wasnt comparing, I was stating different design concepts. F1 engine designed to race, RB25 is designed for a street car to have useable power. That is the key thing here. An F1 car doesn't need power at revs it never see's so all the power is at the top where the engine is used the most
RB25 is designed to be drivable everyday that's why it's not built with the intention of having power past redline, it's designed to have enough power to putt around town or smash it to about where the redline is set, compromise basically
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
