OK, so my R32 GTS(25)T has seen better days...
Has some rust, etc & I am looking at giving it a long term overhaul.
Unfortunately it is currently my only car (maybe not for long) so can't be off road for large amounts of time.
I can pick up a cheap GTR with mechanical problems (engine, turbos, etc) very cheap & want to use the shell as a donor for all my running gear.
So basically would strip it down, remove all AWD gear & fit my stuff in.
Advantages (in my opinion) are:
Wide-body (ish) shell (great for extra track, looks better, etc)
Clutch booster (I run a HEAVY clutch & anything that will help is great)
Plastic fuel tank (won't rust, larger & I assume lighter?)
Plenty of standard GTR bits included with shell (seats, etc)
Can spend time prepping body, etc while still driving my car
Can pick this up for what a BARE GTST shell would cost...
I know GTR rear-end can be used but front end I'm a bit unsure of...
I know I would need to remove GTR front sub-frame & fit GTST subframe but will that just bolt straight in?
What problems am I likely to face? (apart from abuse from GTR owners :whistling: )
Has anyone ever heard of or seen anything like this before?
Or anyone know both chassis well enough that they can give me some definite answers?
Would be much appreciated.
Cheers
Edited by wlspn
https://www.sau.com.au/forums/topic/359668-r32-gts25t-in-gtr-shell/
Like it has been said. DO IT. Leave the GTR rear cradle in it as it has bigger drive shafts, so if you do more mods to increase hp, the larger drive shafts will come in handy. The positioning of the engine mounts are different I have heard. When putting a 26 in a GTST shell, the motor sits a bit further forward compared to the 20 and 25's. It may not be a problem, but it's something I have been told by a mate that put a 26 in his GTST. Not too sure whether you have a similar drama or not going the opposite way.
differences in the front frame rails for one. I would look at where the pickup points for the front crossmember are and start there. if the pickups are in the same spot I would do a literal drop of the front of yours and toss it in the GTR shell. the reverse wont work so if youare going to do major work on teh otehr shell I would suggest making a jig to roll it around on.
as fro doing the engine swap only - no. there are two engine blocks - 4wd and 2wd. they are not interchangeable. the 4wd is wider.
if they were it would have been a lot easier for me . ( I own a GTS4.) I have a WGNC34 RB25 to go into mine.
lol, when he can get the non running GTR for practically free and he has the RWD stuff ready to go, it's a no brainer IMO :)
I do however love egging on GTR drivers that cant grasp the concept that some people dont actually want an R ;)
or GTS4 owners :P
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
