As my build is nearly finished it's time to clear some of the clutter in the shed to make it functional again.
Apexi N1 coilovers to suit R33. Recently rebuilt, however the rears are a bit leaky and should be rebuilt again. Rubber strut tops. Damper adjustable, base height adjustable, spring pre-load adjustable. - $400
http://i21.photobucket.com/albums/b282/tou...le/86270a91.jpg
R33 non-ABS brake master cylinder and booster. - $120
R33 stock complete exhaust, from dump pipe to rear muffler. - $50
http://i21.photobucket.com/albums/b282/tou...le/e09ac5e1.jpg
R33 stock caster arms - $20
R33 stock front upper arms - $20
http://i21.photobucket.com/albums/b282/tou...le/f4b8a62a.jpg
R33 stock air box with Apexi panel filter - $40
http://i21.photobucket.com/albums/b282/tou...le/5bc1743b.jpg
2x sets of R33 front and rear standard suspension. Perfect for clearing defects. - $50 per set
http://i21.photobucket.com/albums/b282/tou...le/49e3257f.jpg
RaceTech 4pt 2" harness. - $100
R34 GTT rear wing. Painted dark blue. - $100
R31 GTS1 27mm sway bar - $100
R31 GTS1 / HR31 Front brakes. 274mm rotors, bendix ultimate pads - $100
R31 aus rear slotted rotors, hardly used. - $100
R31 washer bottle, no leaks, pump ok, cap intact! - $20
Z33 Steering Rack (2003 350Z, JDM). - $200
HKS mushroom filter with adaptor to suit 25det AFM. - $40
Contact via this thread, PM, or:
Phone: 0439 886 240
Email: davidq {at} smartbuildingservices.com.au
I can ship any item at buyers expense.
Preferred payment method is direct deposit, but will also accept cash.
https://www.sau.com.au/forums/topic/359687-qld-shed-cleanout-r31-r33-z33-parts/
  • 4 weeks later...
Interesting .. I can't seem to edit my first post in this thread.
I've dropped the price on a lot of stuff, added some new parts, and removed some that are sold. I'll just repost the whole lot below:
Apexi N1 coilovers to suit R33. Recently rebuilt, however the rears are a bit leaky and should be rebuilt again. Rubber strut tops. Damper adjustable, base height adjustable, spring pre-load adjustable. - $300
XF throttle body on RB30e plenum. Includes modified (bent) throttle cable mount, mount for TPS and throttle coolant bypass. 3" aluminium intake pipe. Mounts to original mounting position. Includes hose for idle air, and return for rocker cover breather - $200
http://i21.photobucket.com/albums/b282/tou...le/6243006f.jpg
http://i21.photobucket.com/albums/b282/tou...le/7a94bc22.jpg
http://i21.photobucket.com/albums/b282/tou...le/152710d4.jpg
http://i21.photobucket.com/albums/b282/tou...le/d870acb8.jpg
http://i21.photobucket.com/albums/b282/tou...le/9275d5c1.jpg
http://i21.photobucket.com/albums/b282/tou...le/03a0b95a.jpg
http://i21.photobucket.com/albums/b282/tou...le/3693d19a.jpg
http://i21.photobucket.com/albums/b282/tou...le/22a1571c.jpg
R31 GTS1 27mm sway bar - $80
R31 GTS1 / HR31 Front brakes. 274mm rotors, bendix ultimate pads - $50
Phone: 0439 886 240
Hi mate,
Is the dog for sale? hi hi hi...
Where abouts are you located for local pick up? I'm interested in those coilcovers but would want the rears fixed before I consider purchasing. Can this be arranged?
