Covered a million times on here before and i have done a search as well..
But basically my new r33 gtr skyline's injectors are leaking from around 3 of them, 2 being at the top of the injector and the other from the bottem..
One of the ones that leaks from the top (nearest to front of engine) just pours out constantly..
Whats the best solution to curing this? car is stock with stock injectors.
Should i just take it to an injector specialist in bunbury (although i dont any) can anyone reccomend anyone? so they can clean and put new seals on (hoping that they are not cracked) and clean them...
Or should i just buy later injectors off a r34 gtr???
https://www.sau.com.au/forums/topic/359711-leaking-injectors/
If it is leaking from the top, then a set of o-rings should sort out your issues.
What you will probably find if it is leaking from the bottom is that it is coming from the centre section of the injector body, where the plastic casing and metal assembly meet. From dim and distant memory mine looked like it was coming out some sort of casting flash on the side. Had 2 leaking I think.
If that is the case, then either isolate the leaking ones and replace with tested good ones, or use it as an opportunity to upgrade.. I bought a set of 700 sards, and to go with it a PFC, and to go with that, a set of -5's, and to go with that........ :blush:
Yeah thought so, gonna read up on how to take em off and inspect them myself...
And then find some were to fix em unless it seems an easy fix then its justa case of getting new o rings hey...
Incorrect sizing??
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
    • Can confirm previous shop that built my motor had no fking clue about oil control and caused my motor to shit itself after two track days. Current shop, Birrong Automotive, has managed to build me a motor, not to mention, has also let me tune it myself and it has yet to blow up after 7 track days. Great oiling success, yashimash.
