As topic states, Big Gold Simmons wheels to suit GTR, these are rare, big and beautiful, fill the guards of a 33 gtr perfect, two rims have very minor clear coat lifting near bolts, hardly noticable. Almost perfect !!
no gutter marks, very few nicks or anything of note!
tyres are rubbish, will remove if prefer!
$3800 delivered to a capital! Located in SA.
pm or text 0403302513
https://www.sau.com.au/forums/topic/359715-big-gold-simmons-wheels/
It did come from NSW ! yeah just rims, new owner wants a bit tuffer look, plus he's gone power hungry so it'll be pulling some good numbers soon!!
price is 3800 or best offer.
265/30/19, yeah sorry, fronts only are running a 10mm spacer, the rim width edge to edge is 275 mm, the best measurement I could get from back lip to backing plate was 160 mm.
  • 3 weeks later...
