  • Replies 482
Was thinking about bringing my 260 along but hadn't driven the GTR in 4 months or so (since Rising Sunday). Will do next time. :thumbsup: Oh, and apologies for not saying hi to you guys - I got caught up with the 34 crowd. All the stags looked good!
yeah at instyle customs is yours the one i see at ELECMEC with the series 2 autech front bar? nd craig well when its done i live in rocko so just pm me and you can come around but probably still be off the road for most of the rest of the year as have to put stereo back in and change exhaust. it will be at motorvation finished but display only as i will be overseas for work i get back end of jan then will be happy to come out for a cruise with everyone
Yep, the front bar looks rs260 copyish but shes only a RS4S.
I haven't seen your car but one of the dudes from instyle wanted a look at my rear windows to make masking easier on your car, or something like that...
Yeah,it was a great night fellas. Driving down the hill at midnight not knowing where/what was coming ahead of me,almost took a short cut straight down to the bottom at one point :whistling:
I'm up for another one as soon as you guys are :thumbsup:
You'll hear from me soon :woot:
Hi guys, I've just purchased a Nissan Stagea.
I've had a Toyota Soarer for about six years so now it's time to learn about a whole new marque!
My Stagea is a 98 RS4S, black, manual so looks like a big old hearse haha. Has some light mods but won't be doing much to it, want to keep it fairly tame and reliable. Will post some pics once I get a chance to take it out for a shoot!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
