  • Replies 482
Hi guys, I've just purchased a Nissan Stagea.
I've had a Toyota Soarer for about six years so now it's time to learn about a whole new marque!
My Stagea is a 98 RS4S, black, manual so looks like a big old hearse haha. Has some light mods but won't be doing much to it, want to keep it fairly tame and reliable. Will post some pics once I get a chance to take it out for a shoot!
Sounds nice :D
I'm pretty new to the Stagea thing myself, but they're a great car.
cheers
Good to see another here. Was this this one advertised on CarSales?
Yeah it was. It has fairly high ks but drives well. I'll get the 200,000km service done a bit early just to make sure she's all ship shape as it turns out I might be moving to SA so will probably drive it across the Nullarbor - not a place you want a breakdown!
The interior did need a good clean out as ithad been a bit of a family car, got a lot of the kid muck out but unfortunately the seats are a little stained in the back. Might look into either dying some sections eventually. it's nothing too tragic in the mean time.
Also need to investigate a better option for the amp install as it currently takes up the right side rear passenger footwell.
It also has some 19 inch rims on it and while they look really cool the ride is affected quite badly. I might return to the stock 17s it came with.
that stag is very nice. plus wheels suit it nicely. very clean.
Indeed 18th and 19th is the Perth round of Track Battle & ADGP, meet and great cruise to the track :P
hell yeah im down for it. meet and greet at ADGP for sure. anyone SOR wonna cruise up to barbs?
I don't know if anyones interested but I have a 98 series 2 stag for sale. Needs a couple of things but it's pretty good price considering... factory manual, r34 gtr wheels.. its in forsale section here for 5k
here are the latest pics of new paint job almost done :) just needs pearl over the top:
looks awesome dude will be pretty epic in the flesh once its finished... Who was doing the paint ?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
