Hey All,
Pickup my “Volvo” last night!
Got a few small things to do to her already like change out coil packs and rocker cover gaskets but apart from that she drives really well.
Items so far:
1997 S1 Stagea RS Four with 170,xxx kms on the clock (has receipts and log book)
Leather interior
Dual moon roof’s
Full kit (Not sure what brand, can someone help with this!) I’m assuming Nismo at the moment…
Bilstein suspension (struts and springs)
Z32 front brakes
Profec boost controller
Shift kitted auto
Tow bar with reece hitch
Greddy boost gauge
Things to do:
Yellow jacket coil packs (installing this weekend)
Install Defi gauge set (this weekend)
Install Bosch 040 (maybe this weekend)
HID head light install
Clear front indicators
Dolphin front grille
Autech or Dolphin rear wing
S2 Tail light conversion
17x10 + 15 BBS mesh rims (or 18x9.5 +20 undecided at the moment)
Photos:
  • Replies 482
here what i have found
Midland towbars will get a towbar 1000kg from the eastern states and charge $795 fitted ....1 week wait and fitting 2-3 hours
rockingham towbars will make you a 1200kg towbar for $850 or a hayman (square tube type for $1050...needs car for 2-3 days
Someone told me that haymen reece make a 1600kg towbar but i rang them and these have never heard of such a car :(
Hey Mazzas,
Yeah mate, same guy on PSB :)
Was into cars way before I found bikes but now share the passion of both types of racing. I actually bought the Stag so I can pack all my track days gear into it and trailer the race bike around and sleep in the back if necessary. The Stag is much nicer than any ute in the same price range plus I already know how to modify work on them.
i am rsvpaul i went for a few rides with you until i had a stack on th aprilia
i will be looking at modifying this one alittle soon just got to remember its actually my mrs car.
I drove it back from adelaide last week and there is plenty ive room to sleep in her :)
  • 3 weeks later...
i think Zack at Cypher Industries is good with stageas. i know he has a c34.
and mel at evoR is starting to get in to them as well
but i do most of the work my self i only send it to some1 if i not have the tools or i have not done it befor
Edited by whitenight27
Well hope ur rough idle is not the same as what mine has.
I have had a slight misfire and rough start in the morning for about 8 months.
In the last 3 weeks the misfire got worse and it started to idled rough at the lights. So I tried another set of coilpacks with no result
Only today I removed the spark plug from cylinder 6 only to find that it was full of coolant :-(
Now having to change the head gasket and hoping that is all thst it is
Haven't posted in a long time, but very desperate here. Need a set of stock wheels with reasonable tyres, or a pair of wheels with decent 225/40/R18 wheels ASAP close to Bassendean. One of my rears just started to delaminate, and the other one is very close to it.
  • 1 month later...
First off, gersfan, ur f**king moving bug thing got me, I tried to squish it :/
Secondly, this page is building a WA Stagea community, for mods/meets and general discussion, already have a few, so the more the better XD
https://www.facebook.com/groups/308340292591887/
  • 1 month later...
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
