Hey all, had a search around but couldnt find much on the location of fuses,
Basically i need to know which fuse i need to remove to turn off the interior/boot lights?
I have opened my boot and jacked up the front pretty high so now i cant close the boot because its too close to the wall lol :stupid:
https://www.sau.com.au/forums/topic/359764-r33-interior-light-fuse/
R33 has three locations where fuses are kept.
1. Inside the car under the electronic mirror controls there is a grey cover with tabs that can be pulled off. Fuse Box English translation (http://justskylines....fusebox_eng.pdf)
2. Engine Bay on the right hand side (driver side) black box pretty self explanatory...
3. In the Boot beside the Battery
Hope that helps =D
Edited by DarkRyda
Ahhh of course, i forgot about the ones in the boot, I pulled a few of the "electrics" fuses on the interior fuse box but had no luck
I guess ill just take out the bulb then beacuse i dont think id get to the boot fuse box where the car is atm pinch.gif
Thanks mate
Yea i didnt wanna disconnect the battery.
I looked for the switch that turned off the light when the boot closes but couldnt see it, do you know where it is chris?
as i said before, i just took the bulb out, i forgot how easy that one is to get out really, but i wanted to know for future where the fuse or switch is
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
